SOURCE: Need an instruction manual
I believe that Bravetti is made by Euro-Pro. You can check the link below & see if it matches your processor: http://www.euro-pro.com/europro/faqdetail.aspx?modelno=EP91 There is a link to download the manual on this page to.
SOURCE: Replacement parts for Bravetti platinum pro food processor
for replacement parts on bravetti products call 1-800-798-7398 or www.euro-pro.com
SOURCE: The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
SOURCE: need a replacement part for food processor
The motor is runing, but the blade is not turning.
SOURCE: instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
-Tha Mp3 Doctor
