Question about Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh 1022 as network printer?
Can I use the ricoh 1022 as a network printer by using a wireless adapter and pluging it into the ethernet port on the printer. Will all computers on wireless network be able to use the ricoh?
  • 1 more comment
  • Anonymous Mar 19, 2014
    password reset
    password reset
  • Anonymous Mar 28, 2014
    replaced two computers on our network and cannot program the ricoh to scan to these computers.
Fdsdfas
Posted on Oct 15, 2008
  • Ricoh Master
  • 2,794 Answers
You can add a wireless print server to it.  Has to be a Parallel based one.  Printing can be done that way but no network scanning can be done if you have that feature enabled.
Posted on Sep 17, 2008
Dell 2155cn
You can make your printer WiFi compatible by connecting it to your wireless modem/router using the Ethernet port on the back of the printer, if the printer is located within a reasonable distance from the modem/router. The cost of an Ethernet cable (even a longer one) is probably less than the cost of the wireless adapter (I assume you have not bought the adapter yet).
To find out if the wireless adapter is compatible with your printer, you can call Dell technical support (for the printer or the adapter).
Hope this helps.
Jul 01, 2014 | Computers & Internet
Sony bravia lcd tv 40 inch
I have a Sony Bravia 46'' TV. I bought a Universal WiFi Adapter from Walmart a few years ago for about $50. You have to plug it into the Ethernet port on the Bravia using an Ethernet cable (the other end of the Ethernet cable goes into the Ethernet port on the adapter). The adapter needs also a power outlet. I do not remember if the adapter came with the Ethernet cable (likely) or I had to buy it separately.
Before buying the adapter make sure that:
1. Your Bravia has an Ethernet port (on my Bravia it is in the back of the TV), and
2. You have/use a wireless router for your home network.
Hope this helps.
Jun 22, 2014 | Sony BRAVIA Televison & Video
How can I connect my printer to my wireless network
If you have a wireless-enabled printer, you can use the printer's configuration to connect it to the router. If you have a wired connection printer (ethernet port) connect it to one of the ports on the back of the router with an Ethernet cable and the printer should sort itself out. If your printer is not network-enabled, you will need to connect it directly to a network-connected computer, then use Windows' sharing settings to share the printer to the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
How do I connect my HP 8250 Wirelessly? I have a router and a Linksys wireless-B adapter.
Make sure your router is set to accept Wireless-B connections...most aren't. Log into your router and setup wireless, using an SSID and security. Then connect with your laptop and you're good to go.
Mar 12, 2011 | HP - HP Photosmart 8250 printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh fax5000L-Can't find ethernet port?
The small ones are for fax
The large one is for ethernet
Jan 26, 2009 | Ricoh FAX5000L Plain Paper Laser
I want to install my mutifunction machine on network
You need to connect the RJ45 cable from the copier to your router, and give the copier the appropriate IP Information. You can then use the drivers avaliable on the ricoh-usa website to install the drivers on the laptops.
Aug 08, 2008 | Office Equipment & Supplies
Toshiba Satellite ethernet port disappeared...
I think you have answered your own problem, your wireless has possibly been zapped.
To test your ethernet adapter on your laptop connect it to a network hub, check the hub and see if you have a link light on the hub and or laptop..
To test your wireless router, connect it to a known working computer with a network card and check the router configuration, using the browser, if you cannot access it then its zapped.
Jul 08, 2008 | Toshiba Satellite A105 Notebook
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox Console
Ricoh Aficio 2022 All-In-One Laser Printer Logo
408 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
