Question about Toshiba 24AF41 24" TV
Toshiba 24AF41 24" TV Problem
It just doesnt turn on, just tic tic tic...
Used to work very nice! I'm learning myselft about some electronics basics.
no sound, no picture. Any advice?
Thanks
  • Victor J Quiros
    Victor J Quiros Sep 18, 2008
    Hey Ginko: Thanks for your answer, about reseting the TV, that the first thing I did, but problems remains the same. I'm actually checking and understanting the board to see if I can fix it myself.
    Thanks
    djkeros
  • Toshiba Master
  • 19,396 Answers
The tic tic sound is a device called safety switch that keeps turning your TV off because an internal fault, such as a defective component or a wrong voltage is detected.
When is like that we say the tv is in protected mode.
Start unplugging TV power cord for one or two hours (it is called hard reset), this will drain power from tv and seset internal circuit, and sometimes can clear the error message, if the fault was only temporary.
If the problem does not go, then you have to troubleshoot the problem, probably some component inside the tv is faulty and may need to be replaced. If you want to do it yourself is better to buy the service manual.
Here you can buy parts and service manual.
If you need to call for repair you can use the phone number listed on the TV owner manual.
Posted on Sep 17, 2008
Tv coming on but wont show
Its horizontal output section circuit has a short circuit. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Insignia NS-27RTV 27" TV
When i plug tv in clicks a few times doesnt power on ,and power light keeps blinking
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the fault...
Jun 10, 2011 | Toshiba TP61H95 61" Rear Projection...
I have a toshiba 26av502u televison that just turned off and now wont turn back on. how do i know if its a blown fuse, or might it be something else.
You need to open it up and check the fuse and other component in the power supply module.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
Apr 10, 2011 | Toshiba 26AV500U 26 in. LCD HDTV
My rca tv will not turn on, But it makes a tic tic tic inside (no its not a bomb )when i push the on button. It is a ac/dc tv for my van.but my vcr works great when i hook it up to another tv. ...
your tv set has a bad relay short it trying to turn on but the relay then detects a fault and lets go (the tick tick sound) it will need to be looked at by a service tech to have the short found and repaired
please rank this advice if it helped
Feb 13, 2011 | RCA E13345 13" TV
HELP ME PLEASE
its simple friend your ps2 version is old and it requieres updates or some sort of that... ps2 slim is new and has been updated thats why it doesnt make any noice try connection yours to the internet..
Jul 17, 2010 | Sony PlayStation 2 (PS2) Console
Sound is not working
Ahh you probably have a partial power supply problem. You can try to see if there is any capacitors that has leak out some fluid, or a leaking semiconductor device. It is really not easy if you don't have any basic electronic knowledge, because it is very technical.
Aug 13, 2009 | Toshiba 14AF44 14" TV
Samsung Rear Projection 47" TV goes into stand by on start up
I am sorry to disappoint you but a TV problem can only be fixed by electronic technician. If you want to do it yourself, you would have to learn electronics. Start by learning basic electronic, and then read a book on how to fix televisions. Without knowledge in electronics, you won't be able to understand a book on fixing a TV. I have been fixing TV since 1998, and I started after dropping out of electronic engineering class. I learned most about electronics on my own, and you can too.
Jun 27, 2009 | Samsung HCL4715W 47" Rear Projection...
PLASE HELP ME TO FIND THIS PROBLEM
Mine did the same, Ceramic Disk Capacitor C506 was burned out.
If you got a nasty smell of burning plastic, that might be it. At least that's what I got.
Dennis R.
Sep 06, 2008 | Philips TS2744C TV
Toshiba 24AF41 TV won't turn on
The tic tic sound is a device called safety switch that keeps turningyour TV off because an internal fault, such as a defective component ora wrong voltage is detected.
Start unplugging TV power cord for one or two hours (it is called hardreset), this will drain power from tv and seset internal circuit, andsometimes can clear the error message, if the fault was only temporary.
If the problem does not go, then you have to troubleshoot the problem,probably some component inside the tv is faulty and may need to bereplaced. If you want to do it yourself is better to buy the servicemanual.
Sep 03, 2007 | Toshiba 24AF41 24" TV
Toshiba MD20FP3 Combo does not turn on. Help!
Not unless you have taken the time to learn all the safety issues concerning the HI voltage safety facts, in the repair of electronics? It sounds like your tv has a problem in the sweep/power supply circuits, and since these sets have NO user serviceable parts< its best too leave these types of repairs to a certified electronic technician. Good Luck
Jun 25, 2006 | Toshiba MD20FP3 Combo
Toshiba 24AF41 24" TV Logo
194 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
