PULL THE STICK OUT RESTART PHONE THAN TURN PHONE OFF INSERT STICK IF THAT DONT WORK USE CARD READER TO FIND OUT WHAT ON CARD {{YOU MIGHT HAVE A BLANK CARD}}
Go to Phone settings>master reset>it will ask you for a master reset code which is 000000 and this reset will clear all the songs,pics and other saved items from your phone memory .
i think u must buy max 512mb micro sd card for U fon,bcos U fon will not support 1GB micro sd card,try to soft U problem,hope can help U,reply me when U soft the problem,[email protected],thk!
if the display on your screen is only half of it, it means that the theme installed in your fone is not for motorola v3x. with regards to the backlight, the connector from the lcd to the board is loose. if you can only see the white light, it means that your fone is running an application, loading or hanging up like what's happening in pc's.
i think you need to master reset your phone and put only a 256memory card. even though it is said to carry up more, just stick with the 256 memory to avoid those problems.
You can either remove the memory card from your unit plug it on a memory card reader to your pc or u can use the default software that comes with your motorola so you can use the usb cable connection.
