Question about LG Washing Machines
Banging pipes when washing machine fills
Hi.  We recently installed a new LG steam washing machine.  When the drum is filling with water, the pipes in the wall bang so loudly that it sounds like they will burst right through the wall.  Any idea why this is happening, and what we can do about it?  thanks so much.
    President:
  • 1,462 Answers
It is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
Posted on Sep 17, 2008
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
When machine operating the pipework throughout the house makes spasmodic banging noise.
Hi, when the washer fills, its calling for water from your supply lines. The banging of your pipes happens everytime it fills. It is a plumbing problem. Need to have a riser installed in the water line which will correct the problem. Thanks
Jan 17, 2011 | Hotpoint Washing Machines
LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Dec 14, 2009 | Washing Machines
Just recently, when the water valve that fills the washer closes, there is a loud bang. Otherwise, the washer works just fine. Is this a concern?
This is called water hammer. It is from AIR in the pipes - and the valve on the washer slamming shut.
There are devices that install into your pipes called hammer arrestors.
Check with a plumber to have them installed properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 09, 2009 | Kenmore 24032\24036 Top Load Washer
We replaced our old wash machine with a front loading LG Steam Washer 2487. When the machine initially fills, it sucks water in short, sharp bursts, which is making our pipe bang loudly. Short of cutting...
This is called water hammer - and is caused from AIR in your pipes.
There are Hammer Arrestors made to eliminate (or lessen) the hammering.
You should also bleed the air from the pipes - and re-prime them.
Feb 01, 2009 | Washing Machines
Water Surge Making Pipes Knock
What you are describing is called "water hammering" and is caused when a water valve shuts off quickly. The momentum of the water moving within the pipe causes the pipe to bang when it comes to a sudden stop. Plumbers can install an air chamber to absorb the water hammer (just like a shock absorber) but you might try ones that you can just screw onto the hoses behind the washer. I have seen them at places like Home Depot in the plumbing department. (hope you can find someone who actually knows what you are talking about to help you find them) Alternately, you may be able to find them at a hardware store or appliance parts supplier.
LG Steam Washer
please give me some more details like model number. that will be easy
Apr 10, 2008 | LG WM-2277HW Front Load Washer
LG Tromm Water filling
water hammer valve at home depot fixes problem for like 20 bucks
Mar 10, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
Feb 05, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
2,643 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
