Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LG Fridge response
Hi there. Thanks so much for responding to my complaint that LG has given me the run around for my parts of the fridge that broke off. The parts are 243a and 243b. They hinge and I was told they were called 'strikers' but i'm not up on the lingo. Any suggestions?
  • 706 Answers
Hi, Here is a website link that provides parts for situations like this..
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1267602&PPStack=1
Not sure which page you will find the lower door hinge pin on but it is there.. you should be able to pick the parts out that you need and order them.. if all else fails.. contact this supplier and explain what it is you need...they should be able to get you what you need... Good Luck...
Posted on Sep 18, 2008
Need fresh parts of my LG fridge GL-T242QM. Two trays and one side container got broke.
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 15, 2010 | LG LRBN22514ST Bottom Freezer Refrigerator
Hello I have a LG GRF 459BSCA Fridge Freezer. The fridge has stopped cooling, We were told to turn it off for a while, then back on again. Now the Fridge freezes!. Could you help with this please and...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | LG Refrigerators
My LG 22850 fridge light stays on all the time
Contacted LG Canada they were great just gave them the serial number of my fridge and are coming out to replace the parts no charge (the fridge is
way outside warranty)
Dec 31, 2009 | LG Refrigerators
Error code er ff.how do i fix this? freezer is still freezing but fridge is warm.
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Oct 27, 2009 | LG LFX25960ST Stainless Steel French Door...
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Air difusser between freezer and fridge will not stop running
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Nov 29, 2008 | Whirlpool Refrigerators
Whirlpool American style Fridge Freezer your response
hi. the fan runs when the compressor is running. so if it does not. replace the fan motor .thanks the appliance doc . please rate me
Oct 01, 2008 | Whirlpool ED2FHEXN Side by Side...
LG Fridge...door strickers
here is a link to an exploded view of your fridge model.. which parts are you looking for? Perhaps your description of the part differs from mine.. what is the part you need? Please be specific so I can assist you in finding a supplier...
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Exploded.pdf
Aug 10, 2008 | LG LFX25960ST Stainless Steel French Door...
Touch Temp Controls
If the touch control doesn't respond then it's most likely bad. They don't normally act up, they either work or they don't.
Jan 05, 2007 | LG Bottom Freezer Refrigerator w/ Swing...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
108 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
