Question about Cameras
My camera's memory card is locked and it will not allow me to take pictures.
  • Anonymous Feb 26, 2009
    My Casio (Exilim EX-Z40 4MP) and SD card have same problem: Thanks to everyone who suggested moving he "LOCK TAB," BUT THAT IS NOT THE PROBLEM. The Lock tab is in the correct "UNLOCK" position but the camera still says card is locked. Two things seem to work to fix the problem but both methods are extremely time consuming, and don't even always work so you have to repeat the process several times to get good results.
    METHOD 1
    The better answer seemed to be to first save photos to a different media (hard drive) then DELETE all photos AND FOLDERS. Sometimes you get a warning while deleting folders that they are write-protected. UNCLICKING "READ ONLY" does not work. What does work is moving the card and card reader to another computer and then trying the same process of either deleting all (I mean all, including "DCIM" folders... and or also formatting the disk. If you get a write protected error, switch again to a different computer. This does not make sense, and it doesn't always work, you have to keep switching computers and you get a 50-50 chance it will work. Try again on another computer if it does not.
    METHOD 2
    THE SECOND METHOD which is (if you can believe it) even MORE time consuming and (yes) LESS reliable, is taking the card out of the camera... then formatting the INTERNAL memory chip from the menu prompts on the camera... then turning camera off, putting in card, and formatting the actual card. Warning: you will lose all your data on the card, so save it before you format the card. The bad news: while this often works, I've sometimes had to repeat this process 7, 8, 9 times in a row. Can take 15-30 minutes to get the camera up and running again. NOT SO GOOD when you have a great photo you want to take. You'll definitely miss your photo opportunity. If anyone has any better info, please share. But these 2 methods work AT LEAST SOME OF THE TIME.
  • 56 Answers
Remove the memory card from the camera. try to look on either of the sides on the card and you will see a tiny latch that locks the card from being over written.
Posted on Sep 17, 2008
Camera shows write protect when open
When what is open? Always keep the battery / memory card door closed. If it is not closed correct, the camera won't work as expected. To protect the file system, when someone should pul out the memory card, while the camera is accessing the memory, it will or shut down completely, or at least protect the memory card against writing to it.
Before opening the battery / memory card cover, always make sure the camera is completely shut off. That means no light is allowed to burn or flicker. The memory card can also be write protected (SD cards) when the lock switch is down like in the picture on the 32GB card.
Before you can make any picture the switch on the card should be up like on the 64GB card on the picture. 3635bcf4-65df-478c-a04d-92e341d15860.jpg
Jan 29, 2014 | Cameras
Camera won't take pictures it show protected card
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 23, 2014 | FUJIFILM A220 Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Just bought x500 digetal camera and can't figure out why it says write protect on screen will not allow to take pictures the memory card is a PNY optima 4GB with the memory card out it allows 3...
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 13, 2011 | GE Cameras
How to unlocked memory card?
A locked memory card will not allow you to write to the card; however, you will be able to read from it. Unlocking the card will allow you to delete files and write to the card. You will want to unlock it before inserting into the camera since this will allow you to store folders or files as well as take pictures with your camera.
first you need Look at the sides of your memory card for a tab in a slot.And then Move this tab up or down to put it in line with the icon that is on the card of an unlocked padlock. This unlocks your memory card. You will want to make sure it is always unlocked before using it in your digital camera; otherwise, it will not save your photos.Then you need to Insert the memory card back into your camera after unlocking to start using it to store pictures.Take the memory card out when done.
Move the tab on the memory card back to the closed padlock to re-lock it. This is not mandatory; however, it will ensure that your photos do not get deleted if other people have access to your camera. You can store the card in the camera or the case that came with the memory card.
That it!
Apr 17, 2011 | Cameras
Took pics with shoot without card setting on
No. This setting simply allows the camera to go through the motions without a memory card, so you can demonstrate it in the shop. The alternative is to lock the camera so as to prevent shooting without a memory card. Either way, no pictures are saved.
Apr 21, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Memory card locked
Move the slide switch on the side of the card.
Feb 28, 2010 | Sanyo Xacti S650 Digital Camera
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Apr 26, 2009 | Pentax *ist D Digital Camera
Cannot download pictures
It seems the files are write protected. Do you have an external memory card in the camera? If so, you might have the memory card's lock on. Remove the memory card from the camera and switch the lock off.
Mar 15, 2009 | Fisher-Price Kid Tough Digital Camera
I recently bought the camera and was able to take 45 pictures without a memory card. I then put a memory card in from my phone and it allowed me to take pictures. However, once I took the card out and...
Be sure that the Lock switch on the memory card in your camera is set to unlock. If it is unlocked then try and see if you can reformat the card with the camera.
Jun 10, 2008 | Samsung Cameras
Cameras Logo
266 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
