Question about Car Audio & Video
Leem power mixer spare part
Hi.
I have a leem power mixer that has a faulty transistor ( blown )
it is a leem Model PM-401D power mixer.
the transistor I am after is D6041
My problem is every w/site I visit do not carry this particular transistor number.I will be happy if you can help, an equivalent will be appreciated
Thankyou
cheers
Dendeng Songet.
Have you tried a 2sd6041? sometimes japanese trannys use this prefix.
Posted on Sep 20, 2008
Peavey PVi 4B - No sound
First, Power Supplies, regulators, condensers.
If not, and you get a POP, probably your Output Transistors (MOS ?) are pulled to one of the voltage rails. Change these.Check for shorts on them or blown ceramic resistors (square white thingies) close to them. Luck !
Mar 04, 2014 | Peavey PVi 4B 4 Channel 100-Watt Powered...
Behringer PMP5000 Mixer. Connected a speakerOn cable to Output A while device was ON. Went to do the same thing on Output B and heard a spark. Turned off the mixer. Now, it will not come on. Checked the...
Chances are you've blown the output transistors. Speakon connectors cannot short out but jack connectors can and if it was not inserted properly you'll have presented a dead short to your powered mixer. In any event it is really bad idea to connect anything when it's switched on. If you're really lucky replacing the output stage (which will probably be dead short on the transistors) and re-adjusting the bias should sort you out.
Apr 08, 2017 | Behringer Europower Pmp5000 Powered Mixer...
I have 110v XR 1220 power mixer and friend of mine plug into 240v power point, blown the two transistors ou. I do not know what short of transistors are they?
There are dozens of transistors in the unit... we can't guess which you might be refering to. The power supply of the 1200 series mixers have fuse before each part of the supply for the preamp sections.
Jul 13, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
Hi, I need the pmp5000 schematic or service manual. Because my mixer smps is faulty.. (On the smps pcb following parts are problem : T12 - D24 and 25? R11 open - D6 and D9 are short - TOP221 ? ) Best...
Oh yeah... know them well The IGBT transistors fail, the sand coated resistors blow open... replace as a pair. The driver transistors get blown... 2SA1020's and 2SC2655-Y's. One or more of the gate speedup diodes for the IGBT's get blown. The switching reg chips, IR2153 is usually gone. and more...
Here is your service manual: http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other "download links".
You will likely find that one of the power amps has shorted... been there, done that several times. Usually the channel A (rearmost) power amp shorts takeing out the 9140 Mosfets and other parts. Often an internal short between an interior and upper layer of the amp circuit board is the fault that causes all this. Use a light bulb (150 watt) in series with the power input when testing after repair. Use an isolation transformer when working on the supply for personal safety. When supply is running again, discharge the 70 volt source caps before plugging onto the amp to avoid welding arcs at the connectors. I have seen the supply hold charge for several days.
Jun 29, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I have a pmp6000 powered mixer. I was running an ipod in and sending out to one powered speaker. I heard a loud pop and smoke started pouring out of the mixer. I immediately stopped using it. This morning...
Cease using the mixer until it is repaired. One or both of the amps have blown. Further use MAY result in power supply damage. 1 to 6 switching power transistors will have blown and often a Zener diode or two. If the metering resistors smoked, there will be two small surface mounted transistors per channel blown wide open as well. These are all in the HCA2400 amplifier module.
Feb 12, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Sep 19, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Audio distorsionado en canal izqierdo
the input selector switches if they are dirty can make the amplifier sound like it has a blown channel.
compare voltages from the left and right channel and make sure they are identical as well as the power supply,typically + and - 65vdc .check the regulators for the pream,they run panel lights off the same circuit + - 14vdc
May 26, 2009 | Marantz Audio Players & Recorders
Leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Sep 09, 2008 | Car Audio & Video
No output to speakers mackie 808s power mixer
I can hardly even tell what you're talking about because you don't use any punctuation.
Jun 10, 2008 | Audio Players & Recorders
Car Audio & Video Logo
354 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
