Question about JVC KD-G230 CD Player
Help!! i have a 05 dodge magnum and i had my jvc hooked up to it all the wire seems to be connected but when i go to cut it on the power stays on for a couple of seconds then turns on but the clock is still running. please help
    New Friend:
  • 74 Answers
You need a special mod to install a aftermarket radio in this car contact your local best buy or Circuit city for the part
Posted on Nov 28, 2008
My 05 magnum want start now but after 3 times of cranking it up an it shutting off now it want crank at all my check engine light is on an the red gas light an lighting bolt symbol I took the battery a...
Probly not starter test the small wire while someone turns the key to start position if u recieve 12 volts starter is bad if not 12 volts checkstarter relay or tipm atached tofuse box
Oct 29, 2014 | 2005 Dodge Magnum
Radio will not go off
Hi Steve, I'm glad to help! I'm assuming you installed the CD Player and now it stays on. Most CD Players have 2 power wires, sometimes only 1. If your only has one then you have your power wire connected to a wire on the vehicle that stays hot with the key in the off position. Here's what you do to find the wire you need. Take a test light and place it on a fuse in the fuse block, then turn the key off and if the test light turns off thats where you want to connect the power wire for the CD Player. Then when you turn the key off the CD Player will go off also. Hope this helps and have an awesome day Steve.
Mar 09, 2014 | 2005 Dodge Magnum
New cd player will not go off in my 05 dodge magmun
All CD Players have 2 power wires, one stays hot all the time and the other is only powered when you turn the key on. Check the power wires, if both of them are hot with the key in the off position then it is wired incorrectly. Look at the instruction and find the wire that stays hot all the time, now find the wire that only powers up when you turn the key on. TAKE THAT WIRE, and find a place to connect it that IS NOT HOT when you turn the key off and this will fix your issue. Hope this helps and have an awesome day Steve.
I installed a cd player in my 05 dodge magnum but it will not go off
Hi Steve I'm glad to help! Most CD Players come with two hot wire, 1 is for memory the other is for powering the cd player. Read the manual and see which one is to power the cd player and hook it to a wire that looses power when you turn the key off. Ths problem is that you have the power wire hooked to a power source on the vehicle that stay powered when you turn the key off. Hope this helps and have an awesome day Steve.
Mar 09, 2014 | Cars & Trucks
05 dodge magnum
What are you boosting the fuse box for,? Are you trying to blow the vehicle up? Where did you learn to boost a car? The car that your useing to boost the car hook up one cable at a time to the batterys of both vehicles The car your useing for boosting hook up the ground to the battery first ,Then on the car that your boosting hook the ground cable to a the engine some where , To ground it, Not buy the belts or moving parts , Then hook up the positive to the postive terminal of battery in the car you are useing to boost the other car ,Hook up positive cable to positive terminal on car that you are trying to get started, If you don,t no what your doing get help from some body that has done it before, One wrong move you can (Screw) Up the computer in the car, End you might of done that (Allready)
Nov 03, 2012 | 2005 Dodge Magnum
The led on my lxa 600 watt amp in my dodge magnum
If the light is all that is on then it will be fine. It would take days to weeks for it to kill todays car batteries. If the amp is drawing more power than just that though, I would move the remote wire to the ignition or the headunit, because the fusebox is getting constant power to tell the amp to stay on.
Oct 10, 2009 | Car Audio & Video
05' magnum keys stuck in ignition
It is possible that your problem is with the shift lock actuator. Charge the battery up. For safety sake charge the battery outside the car. If your ignition is on you don't want to hook up jumper cables. If you do it wrong you can spike the computer. Once you have a strong battery put your trans down in to low and then firmly back into park. The shift lock mechanism is meant to keep you from starting the car without putting your foot on the brake, but if it fails it can be engaged and not let you go back into park. Use a test light to check all your fuses if it still will not work. If that does not do it, start it in neutral and take it to the garage.
Hope that helps.
Rich
Aug 17, 2009 | 2005 Dodge Magnum
05 Dodge Magnum new long block
Might be a bad mass air flow sensor. Need a little more info. I am a crysler master tech so give a bit more info,plz
Jun 20, 2009 | 2005 Dodge Magnum
Deck is powering off every 5 seconds
If radio stays on at low or no volume and cuts out when turning up you may have your battery backup voltage (yellow wire) droping below 10v under signal load. There is a circuit called backup check in radio that moniters Voltage It may seem ok when measuring without volume but under load it will fluctuate with the audio. Try hooking up Heavy guage Ground and Backup battery wires to prevent voltage loss across wires under load. Also check for any speaker that may not be producing proper sound when and if you can get radio working Disconnect wires to that speaker to see if radio will stay on. Just a couple of many possibilities.
kstahl65@att.net
Jan 12, 2008 | JVC KD-S890 CD Player
JVC KD-G230 CD Player Logo
63 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
