Question about Kenwood KAC-7202 Car Audio Amplifier
Kac-7201 how did you fix the problem with your kenwood amp? mine is doing the same thing. when amp is turned on, light blinks and then goes off but the fan stays on constantly. what wast the issue? chris.constant@gmail.com
    Novelist:
  • 77 Answers
Check the zener diodes over by the fuses, where the 2 chokes or load coils are. TThere are 3 or 4 Of the diodes, they are zener diodes. I had the same problem and found it to be one bad zener diode. Check my solution out on the 7202, same thing.
Posted on Feb 10, 2009
Replaced lamp light in Samsung HLT4675XS/XAA 1 year ago. TV is now turning off. The lamp light looks colorful but not bright. The standby light stays on after turning off the TV. Lamp light blinks twice...
I have a model close to yours & mine did the same thing. Its an easy fix the problem is its over heating. Unplug the tv take all the panels off the back of the tv and you will see lots of computer boards but look for one that has heat sinks and & small fan attached to it. Clean all the dust out in that area at the minimum but best to blow out all the dust on everything.
Make sure you are discharged cause if you spark any computer board it will be toast.
Feb 04, 2012 | Samsung DLP HL-P5663W 56" TV
When turned on the lights blink & the fan rotates in sync with lights blinking. Checked codes the are the same, changed the code's & same thing happens
if problems with lights blinking. remove watt governor or ( black box ) then wire lights direct. this will get rid of problem. governor part # 98480-02, hope this helps!! watt governor is on inside for the lights, it is supposed to reduce wattage.
Mar 22, 2011 | Hampton Bay 60 In. St. Regis Fan, Ancient...
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
I have a Kenwood KAC-9105D amp with 2 Kenwood KFC-W3012 subs in a seal box. When i turn the volume up loud the bass fades out for a few secs and then comes back to being loud again, this keeps happing over...
Cant solve the problem but can help calling kenwood in am i have to of those amps and both do same thing its a cooling problem only 1 little fan pulling air out going to buy couple bigger fans and install in both ports and will let u know how it works out
Aug 06, 2010 | Kenwood KAC9105D Car Amp
5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
Red light next to att
Did you ever find out what was wrong with it? Mine just did the same thing!!!!
Nov 01, 2009 | Kenwood DDX-6019 Car DVD Player
What does it mean when the power light blinks on the amp?
genrally kenwood amps are power hungry amps so after playing for a while if it doesnt get the amount of amperage to make it work it will shut down cus you car cant charge the battery long enough for the use of that amp so my idea is try a farad capacitor and see if that helps good luck .......tk
May 29, 2009 | Kenwood KAC-7252 Car Audio Amplifier
KENWOOD KAC-7201 Light flickers ..and fan turns on -nothing works
I had a kenwood amp that did almost the same thing. Try checking you zener diodes. I found 2 bad ones and replaced them and amp works fine ever since. If your not to good at diagnosing, I have my own business installing car audio/video products as well as amp repairs. I gaet amps from all ove the place. If interested send me a message, I'll be glad to help. One more thing, I'm the cheapest person in amp repair. Good luck
Apr 20, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood 7100
Airbag Warning Light Reset Procedure:
The reason for this is that you turned your car on with the airbag warning light for the passenger located in the vent panel above the radio disconnected. To reset it. Turn your car off. without starting the car (foot off the brake) Turn the car to the "on" position. wait for the airbag light to blink. The SECOND it goes off before it comes back on and blinks you need to hit the button again and turn the car off. wait 2-3 seconds and repeat 3 times.
Oct 23, 2008 | Kenwood DNX7100 Car Video Player
When I ignite my stereo system the indicator of ignition of my KAC-9102D is blinking
Here is the link for the user manual for your amp if you need it; http://akamaipix.crutchfield.com/Manuals/113/113KAC9102.PDF There appears to be no designed error code indicated by a flashing power light. the light is either on or off.(page 2) I think therefore that your amp has a major problem in the control part of the circuitry, almost certainly something that needs replacing rather than being repairable. if you wish to try yourself then if you can open the amp up, and post us some clear close up photos then we may be able to help. If you wish to find the nearest Kenwood dealer then; http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=38 Hope this helps - sorry if it is bad news :)
Apr 14, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-7202 Car Audio Amplifier Logo
193 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
