Hi
Hey dear its a virus, luckily your antivirus has already removed it from your pc. one trace is remains in registry which will try to load it on startup.
Ok, do the following step and get rid of it. Open Run , type regedit and press enter Go to
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the value, means it must only Explorer.exe
Ok, then check for the key Userinit. the value must be C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that some thing is there , then delete it. Ok thats all. restart your system .
search window pops open when not doing a search also when I left click my cd rom drive the search...
(More)
search window pops open when not doing a search also when I left click my cd rom drive the search window opens
My problem is identical as what is mentioned above. MIne says that "ACPI multiprocessor pc...
(More)
My problem is identical as what is mentioned above. MIne says that "ACPI multiprocessor pc hardware is not recognized by Windows logo. Install anyway?" Should I install it
