Question about Maytag Washing Machines
My maytag model # LAT8826AAE is not spinning up like it should. every time it trys to go into any kind of spin cycle, the motor makes a humming noise, if i press up on the left hand corner of the washer( where a pulley is located it will grab and start going??
  • 87 Answers
SOURCE: Washing machine belt won't move
You probably have bad spin tube bearings. Look above transmission for a water leak or evidence of one.
Posted on Jun 08, 2007
SOURCE: Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Posted on Oct 29, 2008
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
  • 64 Answers
SOURCE: maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Posted on Jun 10, 2009
SOURCE: washer flashed f-21/ stopped in the middle of
You have to call the serviceman
Posted on Aug 15, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Wwa7304vkl motor hums but does not start
motor is going out on your machine.
Jan 05, 2013 | Dryers
Our whirlpool top loading washer starts making a high pitched whirring noise in the beginning of the first spin cycle. Once it gets going full speed the noise stops. What could be?
If you can hear the motor humming during the spin cycle, it could signal a defective motor drive. It's possible for the motor to fail in just one direction, which may be why you only hear it some times.
This kind of issue often requires the help of a professional. To learn more about this issue, read Washing machine will not spin but will pump and agitate. I hope this helps.
Sep 12, 2012 | Whirlpool Washing Machines
WILL NOT REACH FULL SPIN CYCLE, loud hum prior to spin, starts to spin, hits second speed but will not kick into full speed.
I would suspect that you have a Motor and Motor Control Problem. This washer has a three phase motor in it and it could have one phase out of it or the Motor Control board could be bad. However it is recommended that you replace both at the same time with a motor conversion kit.
Jul 15, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
The washing machine goes through the whole cycle but the machine will not do the spin cycle and I think the agitator has a hard time moving?
If you find this check whether the machine pump out the water from the unit listen for the humming sound from the motor if you found the humming sound means your spinning coil is defective kindly replace the motor
Jan 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
264 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
