Question about Haier Refrigerators
Fridge plugged in not cold - Haier Refrigerators
  • 126 Answers
TOU COULD HAVE A GAS LEAK OR A COMPRESSOR (MOTOR) THATS NOT PUMPING WELL ENOUGH THERE IS NO HOME REMEDY YOU NEED A TECH TO ADVISE AND REPAIR.GOOD LUCK.MHAMED
Posted on Sep 17, 2008
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Ge fridge not getting cold - pds22sfsarss
If this is a new fridge and you installed it make sure all of the shipping plugs are removed.
Sep 25, 2013 | Refrigerators
My Mini fridge Doesn't Get Cold, it's running, I've tried unplugging it for a day and then plugging it back in , still not getting cold..Looked at back and everything looks fine..Except..T
Replace the fridge compressor with another one, try a Google search and maybe you'll find result's for your specific fridge. If all else fails, then ring up your fridge manufacturer and talk to them about your fridge, and if you still have warranty and you complain hard enough, they might just send in a new compressor.
Dec 10, 2012 | Haier HSB03 Compact Refrigerator
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
The fridge part is not cold
turn your control knob all the way off you will feel a click just after 0that is your reset. if that dont work then turn your ridge of at the mainand pull out the plug leave out for 15min then plug it back on.turn your control knob inside the fridge till you hear it clik on if it worksset your knob on 2 in winter 3 summer hope this helps
Nov 25, 2011 | LG Refrigerators
Fridge is not keeping the food cold, water at the bottom of fridge, freezer is not as cold, still freezes things but takes a long time. This is a Kenmore 20 fridge, my guess is 15 years old.
unplug the fridge and leave the doors open for 48 hours, then see if your problem is gone 24 hours later after you plug it back in, if it is, your fridge needs to have a repair to the defrost side of things, most likely the defrost termination therm or the defrost timer, also make sure the drain under the evaporator is not plugged up
Jul 22, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
We have a freezer bottom fridge- the freezer is working but the fridge stopped working. We tried cleaning the vents and unplugging and re-plugging. It sounds like it's on but there's no cold air on the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.Make sure the fan is running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 29, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge is on but not cold. thermostat is on right temp but not fridge and freezer not cold at all
See if frost is on rear of freezer panel. posssible defrost heater ,relay, or timer quit.
Apr 30, 2009 | Refrigerators
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Refrigerators Logo
150 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
