Maytag Neptune MDG5500AW gas dryer has no heat after approx 5 minutes and intermittent periods of a continuous scrapping noise from back. I removed vent hose.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
I have the same problem. When the dryer first turns on the flame goes on and the dryer runs normally. After a few minutes, I hear a scrapping noise just when the coil starts to glow red, but no flame comes out.
