Question about Frigidaire ATF6000ES Front Load Washer
Front loead washer will not spin/rinse,
The water drains but the clothes are all wet. so it will not spin/rinse
  • 1 more comment
  • Jerry Goggins Sep 19, 2008
    The machine skips the spin cycle, so the clothes come out soaking wet.
  • John Voholetz
    John Voholetz Sep 29, 2008
    My machine does the same thing. Everything works fine until it gets to about the 5 minute mark. It should begin to spin, but it just turns off. and beeps like it's finished.
  • TWINTURBOCAV Nov 23, 2008
    I HAD MY WASHER ABOUT 4 YEARS NOW IT DOES NOT SPIN ON DRAIN SPIN CYCLE IT IS NOW OUT OF WARRENTY I HAVE A GREAT DEAL IN ELETRONICS AND MECHANICAL EXPERIENCE. SO I DECIEDED TO CHECK IT OUT I HAVE NOTICED THAT THE DRUM MOVED SO MUCH THAT IT HIT THE WIRES GOING TO THE PCM HAD OPENED THE CASING TO THE RED WIRE AND SHORTED IT TO GROUNG THIS VERY WELL COULD HAVE CAUSE MINE AND YOUR PROBLEM THEY WILL NOT TELL YOU ABOUT THIS JUST CHARGE U.
    I THINK THEY KNOW OF THIS PROBLEM BUT WILL NOT ADDRESS IT. ALSO THEY DID NOT INCLUDE A WIRING DIAGRAM.IT WOULD BE A GREAT HELP IN DIANOSTIC OF THIS PROBLEM FOR ME
    President:
  • 2,712 Answers
First, make sure that you do not overload the machine.
When the clothes are wet at the end of a cycle, check these:
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Sep 28, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
Front loading washer - water is not spinning out, clothes are sopping wet
Hi- Depending on the model the drain pump filter may be clogged; sometimes the drain pump impellers get damaged as well and do not pump out the water efficiently. If it seems to be coming up to full spin speed it is likely an issue with the pump. I'd run a Rinse cycle without any clothes in it and see if all the water drains out. The washer will not got up to full spin if it senses that there is too much water in the clothes (too heavy) to prevent damage to the machine. Probably best to get a Tech to come out an look at it. Good luck.
Sep 24, 2010 | GE Washing Machines
Can I reprogram a front load GE washer so I can add a drain and spin cycle that this machine does not have?.Sometimes my clothes come out too wet and it would be nice to spin and drain them again without...
just add another drain and spin cycle and start it up again with the completion of the first cycle. Washing some items like sleeping bags takes forever because they are so darned absorbent and hold more water than a tiger's sieve of a bladder. Another drain and spin cycle should solve the problem.
Apr 20, 2010 | GE WBVH6240F Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Clothes still wet after final spin
Possible timer or drain problems.. ok.. when your washer is in rise.. before it goes into final spin.. it stop agitating, then drain water for about a minute or two.. listen to see if stop drain for a sec, then began to spin... when it come to draining.. make sure that you hear all the water flow out of your washer.. sometimes when you have a slow drain.. that can do it too.. but the first possible is likely.. good luck
Jan 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Clothes are soaking wet at end of rinse cycle
Awesome website, fixed my problem. Thank you, especially in these times where I can't afford to just call the repair man:)
Jul 09, 2008 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
663 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
