Question about Dacor Preference RSD30 Gas Kitchen Range
Dacor RSD30: No power to the clock face
How do I start solving this issue? I checked the circuit breaker and it's fine.
  • 1 more comment
  • peregrine705 Oct 19, 2008
    Nothing works when the power is put to the stove.
    Pressed cancel/secure...nada.
  • thecollinscl Jan 05, 2009
    No display- Oven not working - Oven light goes on and gas cooktop works.
    Any solutions?
  • fixya135 Jan 18, 2009
    Control Panel appears completely dead. Gas top works and light in oven works.
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Dacor rsd30 celsius to farenheit conversion
Choose the Convection Bake Mode on your controller and select a temperature of 500 degrees or higher. Press and hold Convection Bake for 3-4 seconds and "F" or "C" will appear in red in the display. Using your up/down keys, toggle from "F" to "C", or "C" to "F" depending on your choice. If you hare not using your product, turn it off by pressing Cancel/Secure
Posted on Aug 25, 2008
vanni7
  • 163 Answers
SOURCE: Does the Dacor rsd30 have an internal circuit breaker?
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
Posted on Jan 04, 2009
dovaleh
SOURCE: Dacor Oven Death
hi,
i think first you should call dacor, 4 months is marginal - they should cover it
but if all else fail you can try this link ti diagnostics manual:
http://dacorservice.com/PartsCatalog/docs/ProductModels/437/Diagnostic_Manual.pdf
and this link to dismanling instructions:
http://dacorservice.com/PartsCatalog/docs/Ranges/Service%20Manuals/ERD30s06_sm.pdf
good luck
dov
Posted on Jan 10, 2009
DACOR RSD30 RANGE . NO CLOCK OR FUNCTIONS SHOWING
Turn breaker off and on control may reset and work if not
you need control witch is not available
option 1 we can do upgrade to covert control to newer dacor system
cost is around $1400 can if you are in our service area
option 2 other than that you can have control sent out for rebuild they can not always repair
option 3 call dacor they may offer you a discount on new range as parts are no longer available
good luck hope breaker reset works
Sep 18, 2017 | Dacor Kitchen Ranges
The oven shut off half way through baking on convection, the fan still works, the clock still on, other functions seem to work but now the oven will not come up to temperature what can cause this?
The door closure latch can cause such an issue, if is isn't engaging correctly. Otherwise your RSD30 may need to be reset. Follow the instructions in the owners manual to reset. If you don't have a copy, the link attached below is free to use. Dacor rsd30 User Manual
Mar 12, 2015 | Dacor Preference RSD30 Gas Kitchen Range
Problem with Dacor Preference RSD30 Gas Kitchen Range
most common issue is burners not placed on proper
may have spider web in tube
possibly bad regulator if 2 large burners lazy,2 small ok ?
Dec 01, 2017 | Dacor Preference RSD30 Gas Kitchen Range
We reset the power at the breaker and it did not fix the problem - up and down arrows on the keypad do not respond, while all other buttons seem to work correctly. This is a strange problem that has...
Clock issues seem to be the norm with Dacor, best advise is to call customer service, i am in the repair business and get many service calls for this range. Save yourself the $65 to $85 service call and call Dacor Directly @ 800-793-0093 you will need model number and serial number would be helpful. Good Luck, hope this is helpful
Dec 26, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Jan 04, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Clock is in Military time...can't change it back...
If you call Dacor they will talk you through the solution but you have to have another person ready to turn the breaker off while someone is pushing a button. I have contacted them and am trying to get the instructions emailed.
Dacor Toll free: 800-793-0093 have model # ready
Oct 11, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Epiente 36"Range Oven Contrrol Panel won't work.
does the clock work? try a hard reset (turn off the circit breaker for 1 min .. then turn back on or you can also check TCO you under the grille be sure to turn the power off
Aug 24, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor error messge
The Door lock safety circuit on power relay board sensed. Check your power relay board and door lock circuit. F9 indicates the problem is with the lock circuit. Shut the power off and see what happens if nothing then do the checks. You can have a problem with the latch assm. the lock switches the relay or even the ERC (electronic range control).
Dec 20, 2007 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference RSD30 Gas Kitchen Range Logo
37 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
