Question about Intel D865GBF Motherboard
LAN CARD PROBLEM
DEAR SIR,
I HAVE MOTHERBOARD INTEL D865 ,I FACE PROBLEM IN PCI LAN CARD ,THE CARD ALREADY OK, IN WINDOWS STATUS THE CARD SHOW INSTALL BUT NO CONNECTIVITY , THE MOTHERBOAR IS OK TOO , BUT IDON'T KNOW WHAT THE REASON ,I TRY ALL TROUBLESHOOTING BUT NO RESULT.
KINDLY PLEASE SUGGEST ME AND ALSO SOLVE IT IAM VERY WORRY ABOUT IT ,
THANK YOU IAM WAITING YOUR ARGENT REPLY .
    Master:
  • 351 Answers
Janab Khan Saab,
Well this Motherboard already comes with onboard Lan Card , did you need additional LAN ,through PCI , if yes then may be the IRQ of both lan cards is clashing with each-other please try this to assin different IRQ.
Please update me.
Regards
Posted on Sep 17, 2008
Dear sir/mam, i need some drivers about intel 945dgccr lan drivers for WINDOWS7 how can i get that
Intel's downloads page for your board is here. The board is discontinued, so they haven't updated all the drivers for Windows 7. These are the LAN drivers for Vista, which is all they offer. If Windows 7 doesn't recognize the LAN on its own, you can try the Vista drivers. Sometimes Vista drivers work with Windows 7, but if they don't you will need to use a new adapter compatible with Windows 7. You can get a PCI card and install it inside the case, or get a USB Ethernet adapter which you can plug in without opening the case.
Feb 07, 2011 | Intel D945GCCR Motherboard
My mother board D865 GBS cannot accept drivers from CD only VGA drivers. Audio or LAN card drivers are ok.
Dear Asif,
Click here to download the drivers for Intel D865GBF Motherboard. (It has Intel Extreme Graphics D865)
Choose your Operating System and get the drivers
Hope this helps! Dont forget to rate the solution!!
CreativeTECH
Nov 29, 2010 | Intel D865GBF Motherboard
I have purchased and Intel motherboard which has a Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC card. I am unable to use this to browse the net because RHEL 5.0 does not have the linux drivers for it....
hello sir,
u can access net. there is absolutly no prbl with the "Intel motherboard which has a Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC card" . u need to install first the drivers of LAN from ur motherboard driver cd. thn restart ur pc. if it has again counter a problm thn u can use any download trial version of linux drivers.
thanking u
Jan 25, 2010 | Intel DG31PR Motherboard
LAN is not recognizing Internet port
Then you have reinstall *********** boards drivers from its cd.
Oct 25, 2009 | Intel DG31PR Motherboard
Intel d865
Sorry to say M8, but you cant!
Here is intes support for that MoBo and there are non drivers for vista at all. So that card cant be upgraded to vista open gl
http://www.intel.com/design/motherbd/bf/bf_drive.htm
Nic
Feb 10, 2009 | Intel D865GBF Motherboard
Lan on motherboard D915GLVG
Unplug your computer and Install a lan card into any available PCI slot.  Restart your computer and install the CD.  The CD will load up the drivers when needed.  You may have to start your computer once completed.
Sep 17, 2008 | Intel Motherboard
Intel d865perl sound card drivers
left click this link & choose you're operating system for the Intel D865PERL motherboard drivers. (Reinstall the driver software).
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=949&lang=eng
For windows XP/home & pro. Click on this link;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=949&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
After reinstalling the software & you're sound does not seem better than the built in sound chip may be going bad.
Other factors can also cause the effects you are having. Run windows system defrag. Also run windows Disk cleanup. These tools are found in windows System tools. Lastly you can buy & add a PCI sound card into an emty PCI slot to bypass the built in sound card. If you choose to do this you will need to enter the bios & disable the built in sound device.
Good Luck!
Mike
Jun 27, 2008 | Intel Desktop Board D865PERL...
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Jun 18, 2008 | Intel D845GVSR Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Intel D865GBF Motherboard Logo
112 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
