Question about Car Audio & Video
Jensen vm 9312 parking brake bypass - Car Audio & Video
  • 1,586 Answers
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Posted on Sep 17, 2008
    Scholar:
  • 173 Answers
The wire color is pink take the wire and conect it to a toggle switch its power prong and take another wire and ground it to a chassis ground some were under the dash will work make sure its paint free now ground it off and run the wire to the switch and flip it on and waite for 15 seconds if nothing hapens flip it again it should show a picure
Jensen vm9314, how do you bypass the parking break safety feature to watch videos any time?
Try connecting the PINK wire of your head unit to a ground/chassis of your car. That should solve your problem. happy viewing but drive safely. dreamsystems
Feb 15, 2011 | Audiovox Jensen Vm9314 Dvd Video Bypass...
Need schematics on jensen vm 9312
If you mean the circuit schematics, then you won't have much luck. That information is proprietary to Jensen and they don't make it publicly available.
May 16, 2010 | Jensen's VM9312 Car DVD Player
How to hook up Jensens Vm 9312 car stereo indash
how do you make the navigation work on the jensen VM9312
Jensen VM9312
Feb 04, 2010 | Jensen's VM9312 Car DVD Player
No video in my jensen vm- 9312
There must be a safety mechanism on the thing. There must be a wire that monitors the state of the parking brake. Look in the manual and see if you need to ground it or connect it to power in order to disable it.
Dec 21, 2009 | Jensen Car Audio & Video
Emergency brake wire connection
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Apr 12, 2009 | Jensen's VM9312 Car DVD Player
Jensens VM 9312 car DVD player problem
Just go to the set up menu ( Your screen should say setup at the upper center of your screen ) Then press 5, 4, 3, 2, 1, 0 with your remote control and a second menu will apear, on your left side press the second option and select parking bypass to on.
Sep 03, 2008 | Jensen's VM9312 Car DVD Player
Jensen Vm 9512
if you want to play dvds well you drive you just need to put parking brake wire (pink) to ground no code needed
May 25, 2008 | Audiovox VM9512 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Jensen VM 9022
Access the setup menu and while there put in security code on remote, 012345, or 543210. Once entered you will gain access to the secret menu, scroll down to the braking option and select the brake off option. Enjoy....
Nov 30, 2007 | Jensen Car Audio & Video
Car Audio & Video Logo
248 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
