Question about Coby MP550 MP3 Player
Coby MP550 MP3 player problem
My Coby MP550 won't turn on. It charges and I can acces the files on it if I plug it in to my computer, but once I unplug it, I can't turn it on. Any ideas?
  • 3 more comments
  • sathishrulzs Oct 22, 2008
    my coby mp550will detect,but i can't access it.the capacity is not seen on the property.what should i do
  • Anonymous Nov 15, 2008
    i can transfer and access files from the mp3 player but i unplug it from the charger i hold the button down until the light turns on but after that no music plays
  • Anonymous Feb 21, 2009
    Mine is exactly the same =/
  • Anonymous Mar 31, 2009
    tengo el mismo problema la verdad coby es una porqueria si alguien puede ayudarme porfa ya la la respuesta es muy confussa mi imail es yupo_159@hotmail.com
  • Anonymous Mar 18, 2014
    When I go to plug in my Coby MP3 player, the computer makes three beeps and it doesn't charge. I am unable to turn it on and I've tried different cables. Please give me some advice.
1. Make sure the hold switch is in the "off" position.
2. If the light comes on but your media doesn't play, it could be that you've load files which have DRM applied. The player does not support DRM, and thus can't play the files.Try playing a file that you are 100% certain does not have DRM applied.
3. If the light does not come on, the battery is fried (if LiPo batteries discharge past a certain point, they have a tendency not to recharge, no matter how long you leave it on charge). Return the player to the store where you purchased it.
Posted on Feb 04, 2009
How can i download music from my computer to my mp3?
When you connect your mp3 player to the PC. It should open up a file with the name of the device in my computer / scroll down to find the device, click and minimize the window,open the music file and drag and drop.
Aug 06, 2014 | Coby MP550 MP3 Player
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
Drivers for Coby MP3 player model no MP550-2G. I have windows XP
Having Operating System Windows XP, most mp3 players can be recognized in Windows Media Player 11 software from Microsoft.
How to use WMP11 look on next site:
http://www.microsoft.com/windows/windowsmedia/player/11/using.mspx
You can also use Coby Media Manager from the manufacturer for media transfers. See next page for how to download and install Coby Media Manager, for XP download the execute file coby-mediamanager-2009b0924.exe on next site:
http://www.cobyusa.com/?p=fix_mp822
After download and installation, run Coby Media Manager:
select Tools > Device Manager...: select MP-550 from the list:
click Add : click OK to have the MP-550 as your operating device.
Under Device Configuration you can set the synchronizing location and
bitrate conversion for audio.
Need more help ? Just add a comment.
Apr 10, 2010 | Coby MP550 MP3 Player
No reproduce musica mi mp3 coby mp550-2g
para poder arreglar el problema de el repoductor de musica COBY MP550-2G solo agan esto:
Boton derecho sobre el dispositivo, Formatear, y cambien el sistema de archivos por el el de FAT 32 y el tama?o de unidad de asignacion por 16 kilobytes.
manchux_sama@yahoo.com.mx
para alguna otra duda, claro si es que puedo responder XD
Jan 30, 2010 | Coby MP550 MP3 Player
My coby mp3 player says no format i can plug it in to my computer and it will download but when i try to play my songs it say no format and i cant get around it how do i fix it
i have a problem with my coby MP550, i lost all the files in my Coby it's very empty cause by mistake am reformatting my coby. somebody can help me please?
Dec 01, 2009 | Coby MP550 MP3 Player
Coby mp550-1g no light, not charging.
If it is hanged up, then it might have a virus. It is better to reflash it an reinstall the firmware. Secon thing is it's battery need replacement.
Jul 06, 2009 | Coby MP550 MP3 Player
I dont know how to use my coby mp550 mp3 player
Read. The. Manual. I'm sorry if this sounds rude, but it really should go without saying. If you've lost the manual, Look for it at the Manufacturer's Website.
But essentially (and generically): To turn on: Press (and maybe hold down) Power Button (sometimes play button) until turns on. Ditto to turn off. To Charge: Plug it into the Computer (Make sure the computer is on). To sync Music. Plug it into the side of the computer, open WMP. Look for device in Library. Drag songs/playlist across.
And in future. Read. The. Manual. Thank You.
Feb 03, 2009 | Coby MP550 MP3 Player
My coby mp3 mp-610 keeps saying file sys err hod do i fix it
not responding the coby mp3 550-1g player on my computer
Dec 29, 2008 | Coby MP550 MP3 Player
How to manage files on a coby 550 clipp mp3 player
HELLO, I'M UNABLE TO PLAY MUSIC WITH MY MP3 PLAYER,WHEN I TRY TO SEND MUSIC FROM LAPTOP IT'S SAYS...REQUEST FOR DRM TIME...I NEED YOU TO PROVIDE THE SOLUTION TO THIS PROBLEM SO I CAN ENJOY MY MUSIC PLAYER.....YOU CAN SEND ME THIS SETTINGS OR SOLUTION TO MY EMAIL ADDRESS...pauladiele@yahoo.com
Dec 16, 2008 | Coby MP550 MP3 Player
Coby MP3 mp550 -1g
my mp3 player wont turn off or charge some one please help me.............. help help help
Oct 15, 2008 | Coby MP-C7085 MP3 Player
Coby MP550  MP3 Player Logo
389 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
