Question about Mitsubishi VS-45603 45" Rear Projection Television
Mitsubishi VS-45603 I have a Mitsubishi VS-45603 and after watching tv and losing power, I lost all my inputs except ANT-a and ANT-b. I looked thru the whole owner's manual stll can not figure it out, also tried to fix by using the menu on the tv.
  • 1 more comment
  • 1803750 Sep 18, 2008
    No additional comments!
    Unpluging TV did not resolve problem.
  • 1803750 Sep 19, 2008
    Thanks for the assistance, all is well. Best $10 that I've spent in a long time!
    Scholar:
  • 73 Answers
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no.
I think this will work.
Posted on Sep 18, 2008
    Genius:
  • 2,035 Answers
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
    Brigadier General:
  • 6,966 Answers
A very similar issue posted here was corrected by:
  • go into the menu;
  • setup;
  • a/v connection;
  • verify that "locked to input" is selected to NO.
as presented in the same post above by Antwain75.
Should this not be corrective in your particular concern, then you would need a Service Manual. Your Mitsubishi VS-45603 uses the VZ5 chassis.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 726 Answers
Unplg the whole tv from power again then take out everything that is plugged in to it then plug the tv in then all the inputs again give that a go
Posted on Sep 17, 2008
  • chris07551 Sep 18, 2008
    might have blown the inputs when the power went out you will need to open the tv and test them
  • Mitsubishi Master
  • 13,433 Answers
Hey, try unplugging the tv for a few hours, it should reset the memory and hopefully get you your inputs back.
After big storm the tv only shows small picture in upper right corner. Will not allow to go to full screen. VS-45603
You are in pip mode, and if itwill not let show on regular mode, then your tuner is out,and youcan bypass it and go directly into the video input with RCA cables from your recieever,and put your set in video mode,better picture, and save you 500 dollars on a new tuner.
Jul 07, 2011 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-45603 had power outage and when it came back on it says TV is locked. How do I unlock it?
Go into the 'Menu' -> then 'Setup' -> then 'A/V Connections'.
You should see an option called 'Locked to Input' switch it to 'No' and your problem should be solved!
May 05, 2011 | Mitsubishi VS-45603 45" Rear Projection...
No picture
make sure the tv is in the correct input, either tuner channel 3 or an a/v input
Dec 16, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-60603 60
this was the perfect solution..my whole family thanks you for this information. It worked in two seconds!!
Jun 22, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-50603, input is gone
happened to me also. Go to the menu, select setting, thrn av (home theater) and see if "locked to input 1" is "on". Mine was. then I set it to "off" and everyting works great
Dec 06, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi vs-45603
This set is not HD capable.
When all signals are supposed to go to High Def., there is supposed to be a box that will convert the signal from 1080i to 480i.
I'm not sure how it will look, but, the down converted signal seems to look good for now.
The new technology is coming down in price and the new features are coming at us at record speed.
For instance:
The new tuners are capable of receiving local high definition stations using rabbit ears.
You don't need a cable box to receive all stations (except premium stations such as HBO) including High Definition if the turner has a "Clear QAM" tuner.
LEDs being used in LCD and DLP make them less vulnerable to loss of lamps prematurely and a heartier set.
LCDs and DLPs are becoming the set of choice due to contrast ratios as high as 100,000 to one and unlimited color.
A new type of set is just around the corner using laser technology (from what I have been told by manugactures).
In conclusion:
Your set is not HD, but, it should still operate when or if the change does take place. You may need to get more equipment to help with this change and it may cost more than buying a new set.
Nov 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Blue screen and sound but no picture, except in PIP mode
The lighting possibly damage the tuner of the set,for now you can swap the pip with the main picture and change the channels with the vcr,you need the assitance of a service to diagnose how much damage is there but.Let us know what you find or if you nned more information.
Oct 06, 2006 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
437 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
