Question about Olympus FE-280 Digital Camera
Lens trouble My lens will not come out entirely on my camera, for when I push the button to turn it on, the lens tries to completaly come out but then quickly retracts back halfway and remains stuck about halfway open. The screen is black and the light flashes red everytime I turn on the camera, along with a noise of something stuck. I have tried using that little button that someone told me was the reset button, along with plugging it in, and charging it. None of this has helped me with fixing my camera and I was wondering if any of you could help me wit my probelms. I'd be truly grateful for any help offered to me.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Appears to be a repair issue... lens track may be off
Posted on Sep 19, 2008
52mm lens stuck on body,,how do you unstick it?
Normally, these lenses do not 'unscrew'. When you push the red button, it releases the lens catch and then you rotate the lens a short ways counterclockwise, then gently pull forward on the lens while holding the body of the camera and the two units separate. It is possible you have gotten some dirt into the lens latching mechanism. Try returning the lens to the locked position, press the red button, rotate the lens to where it stops and then returning the lens to the locked position and repeat several times if the lens does not lift out when you hit the movement stop. This may allow you to get past the dirt. Otherwise, take it to a camera shop, particularly if the camera is still under Canon warranty.
Dec 04, 2014 | Canon EOS 550D Rebel T2i Digital Camera
I accidentally pushed my lens in while taking a picture so now when the camera thinks it at no zoom it has a 24 zoom (number on lens) How do I fix?
Hi and welcome to FixYa!
This problem does occur. As a first course of action I strongly suggest that you remove the battery of the camera and turn the switch on for 10secs. while the battery is removed. After 10secs. insert the battery then turn the camera on. This should reset the system and may get your camera back to it's normal operation.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 15, 2011 | Canon PowerShot SX30 IS Digital Camera
The entire zoom lens will not come out when I turn the camera on. It moves a little, makes a sound, and then my camera says turn off camera off and back on. I tried that several times and it is still not...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 25, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Jun 04, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Casio ex-z77/ lens error
you might have pushed the lens into the barrel. small lens barrel has 3 metal pins that ride inside the larger lens barrel as it twists. Pushing it sometimes cracks the plastic holding these 3 pins in. one way to fix it is to carefully disassemble the entire lens barrel. be careful...sometimes a part just snaps, or is already snapped. The easiest way would be to replace the lens assembly with a good one you can get from another camera like this. There are no spare parts for cams like this so you can try to get another cam that has a different damage other than the lens barrel.
Jul 05, 2009 | Casio Exilim EX-Z77 Digital Camera
Nikon D50 While shooting pictures the shutter button stopped work
TURN ON CAMERA. SEE IF THERE IS A MESSAGE. NOW, TURN OFF CAMERA. TAKE OFF LENS. REPLACE LENS- MAKE SURE YOU HEAR A "CLICK" TURN ON CAMERA AND TRY AGAIN. OK?
Mar 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Lens are not coming out
Did you put the lens on up-side down? Don't laugh, it happens. If so, hold the lens lock button in (on camera body)and give the lens a quick counter clock wise twist. It should snap out.
If on correctly, turn lens clock wise while pushing in lock button,then with button still pushed in turn the lens counter clock-wise.
Nov 16, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
Lens error
try turning it on and when turning it off push the lens
Sep 09, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera
It a lens misalignment try tapping the lens gently in an opposite direction the camera dropped on and that should pop the gear back into place
May 12, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Lens stuck out; camera won't stay on
I have the same problem. Its actually because the On/Off button got pushed in somehow and its stuck. At this time right now, im not sure how to make it unstuck, but sometimes it will stay on. But when you push on, since its being held down, its stuck that way and immediately turns off because its still being held down constantly. Maybe try using a thing needle to try and push it out?
Nov 13, 2007 | Kodak EasyShare M853 Digital Camera
Olympus FE-280 Digital Camera Logo
194 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
