I hv sansui flatron tv and from 1 month i hv problem in my tv that my tv screen black after few minutes but sound is on but screen black and after sometime it will reappear. and some time it work properly.what is that problem.
Re: I hv sansui flatron tv and from 1 month i hv problem...
If possible eaily take it straight back to the shop it came from or whatever advice the instruction book tells you depending on where in the world you are.
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Now u turn on the tv the tv pictures only flashes a few sec.than dies,but the tv still have audio sound left only?Yes,mean ur tv have a 1 or 2 long boards that are call a LCD inverter boards are the causes and the problems.These 1 or 2 long LCD inverter boards only job are to provided the tv LCD screen panel for a backlight for the tv to have picture only.Tries websites like Shopjimmy.com,Ebay.com to buy a 1 or 2 the tv long LCD inverter boards for the replacement.
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Today, after speaking to the Sansui Manufacturer representative from Japan. He stated that all you need to do is to turn off the closed caption from the TV remote and not the DVR remote. Black screen can occur at the top half or the bottom half of the screen depending on how it was originally setup during installation. Try this and hopefully this fixes the problem.
do you get sound while screen does black? what do you mean by "until eventually it has turned black and will not come back"? is it black from the minute you turn the tv on untill you turn it off? if sound is good but picture is black, it may be the resault of a fried monitor tube, in this case replacement will cost alot.
if sound is dead also, them it is probobly power supply related issue. get out your DMM and measure the voltages in the power supply. When the screen goes black, is there still regulated B+ going to the circuitry? Do you still have HV? Is the filament of the CRT lit? Does the set still have a raster (you may have temporarily increase the screen setting to see it)? Do you measure any of the flyback derived B+ voltages that go to the video processing, tuner, Vertical Deflection, and other circuitry?
