Question about Toshiba Satellite A105 Notebook
Laptop Won't Boot
This may seem a silly problem, but my Toshiba laptop will not turn on and I wonder if, should it be a battery problem, then it should turn on if using charger? Mines will not do that. I don't know whether to buy a new charger, or battery, or both. I'm inclined to think it's the battery as even when it's been charged and is then unplugged from electrical socket, the battery runs out in a matter of minutes.
  • feething Sep 17, 2008
    Thank you. I thought it was perhaps charger and glad to have that confirmed, saves me money buying a battery:)
  • Toshiba Master
  • 6,487 Answers
This can be a problem with the power supply unit of the laptop itself because if this is a problem with the battery the laptop should boot up if its plu in to a power outlet but you said it still not power on, so its not problem with the battery or the power adapter...
Hope that helps.........
Posted on Sep 17, 2008
  • 97 Answers
You'll need to troubleshoot your laptop in order to know what the exact problem is. First try to plug it in with the battery on and try turning the laptop on. Next would be to remove the battery and plug the computer. If this doesn't work then it's definitely the AC Adapter and you'll probably need to call toshiba to purchase a new one from them or if you're still under warranty then have it replaced. They also have some qualifiers on whether an AC adapter or battery is qualified for replacement even if it's under warranty. Just call them on 1-800-457-7777 and ask their technical support reps about this.
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
My Toshiba Satellite A105-S2031 laptop won.t boot up. When I turn on the laptop the two small lights below F 10 and F 11 light off then the computer turns off.
Try removing the battery (in case it's shorted), plug in the power adapter and boot to bios (using F2, F10, etc). Be sure there are no USB memory sticks connected, etc. If you are able to boot to bios, great! Then, it's a matter of eliminating the root cause: either battery or hard drive. If you don't boot to bios, then you're most likely facing a hardware problem. It may be as simple as an unplugged cable.
If you can't boot to bios, consider connecting an external monitor to rule out LCD display problems.
Aug 09, 2013 | Toshiba Satellite A50 Keyboard
Toshiba P745-s4102 won't boot or restore to factory settings
I have Toshiba P745- S4102 . When I open a window it freezes. I have to do a hard shut down each time I turn on my laptop.
I want recover my laptop to it's factory setting. I brought the laptop from bestbuy brand new. It did not come with a CD for recovery. I have windows 7
Apr 18, 2013 | Computers & Internet
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
Nov 10, 2012 | Toshiba Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
I have a toshiba m305d-s4830 laptop. It won't turn
there must be a problem with your memory. if the lights are on and it not continuing booting then F2, it might help.
all the best!
May 15, 2011 | Toshiba Computers & Internet
Boot passward issue with Toshiba Satellite A215-S7413
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 13, 2010 | Toshiba Satellite A215-S7437 Notebook
Wondering where cmos battery is on A105 Toshiba Sattelite S2061. I replaced the normal battery that wasn't charging now I can't get my system to boot. The laptop is a few years old now and for the past...
The cmos battery is located on the motherboard. It looks like a little round hearing aid battery. Usually they are around $5 to replace. Hope this helps.
Jan 26, 2009 | Toshiba Satellite 5005-S504 Notebook
Need to bypass password on toshiba t4850 laptop..??
well than don;t buy stolan laptops ! (if the case here !!!)
anyway, u;ll have to open it , and reset the BIOS ! (remove for a few seconds the small battery inside ) ... check for the computers manual ... all should be there ...
Dec 10, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A105 Notebook Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
