Question about Jl Audio 12W7 Car Subwoofer
12W7-3 JL AUDIO SUB
VIBRATION LIKE SOUND COMING FROM INSIDE THE ENCLOSURE ALONG WITH AN UNWANTED ODOR OF SORTS, I BELIVE THE VOICE COIL HAS COME UN DONE FROM ITS SURROUNDINGS.
POSSIBLE SOLUTION COULD BE WHAT AND WHO CAN FIX. ?????
  • 185 Answers
Ok well sounds like u beat the snont out of it but call jl up and tell them whatz going on with it sorry cant tell what i can tell u is take it easy oon the sub if ur smelling oders from the sub its getting ready to blow so just keep it down
Posted on Sep 26, 2008
What's the best way to hook up my jl audio 13" w 7 sub to my jl audio 1000/1 amp
the best way? hmm. i would start off with some wire. Keep in mind that you will need to separate the positive (usually red or has a stripe or marking on it) from the negative (Black usually is the common color for this wire) and hook the up according to your amps positive and negative hook ups / terminals following your sub-woofers terminals. then depending on your sub woofers Voice coils (Duel or single voice coils) yours are duel or quad coils but i\'m sure they are duel (2 of each positive and negative equaling a total of 4 posts on each sub-woofer). figure out your amps ohm load handling and does your amp run hot (1,2 or 4 ohm stable some are even less like 0.5 or lower) i would run at a 1 or 2 ohm load as that is usually standard on 1 channel amps. make sure to check your wiring and if your not sure about ohm loads just Google wiring for sub-woofer ohm loads such as 0.5 ohm, 1 ohm, 2 ohm or 4 ohm loads. also make sure your box is not sealed do to the fact they are siht and cant produce sound like a vented / ported enclosure keep the size as big as you can fit in your car or truck the bigger the better. i had one 8\'\' sony sub pounding like a 15\'\' sub real loud . Also MDF particle board is garbage it causes port noise and absorbs water
Apr 28, 2014 | Car Audio & Video
My 12w7 has like a springing sound inside it, what is it?
Blown voice coil,,,,it was connected to a JL AUDIO amp correct? w7`s can ONLY be powered by JL amps due to ohm load.Advice buy a better quality sub,w7 is over-rated
Feb 07, 2013 | Jl Audio 13W7 Car Subwoofer
I think its my voice coil but I might as well ask to make sure. At higher volumes, my W7 will make a wierd rattling sound from inside the sub. Is it the voice coil or something else?
tinsel lead on terminal needs to be coated with a layer of black rtv sealant where it comes out of voice coil on back of speaker temporary fix since you have OVERPLAYED your subs,
Feb 22, 2011 | Jl Audio 10W7 Car Subwoofer
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
How 2 wire 3 jl audio w6 v2
Hello mikey4569mky,
Unless your amp is stable below 1 ohm, there's really only one wiring solution. And that is to series the voice coils making each sub 8 ohms, then parallel all 3 subs to the amp for a 2.67 ohm load. If you parallel the voice coils and then parallel the subs, the impedance will be 0.67 ohms, much too low for most amps.
You could parallel the voice coils and then series the subs for a 6 ohm load, but the amp won't put as many watts into a 6 ohm load. Most are optimized for 4 ohms or 2 ohms. And it's not good to run subs in series anyway.
Here's the wiring diagram.
Hope this helps.
Sep 13, 2009 | Jl Audio 12W3 Car Subwoofer
JL AUDIO 12W7-3 SUB
the rottem electronic smell is the voice coil burned up as well as the bad sound, isn't the 1st time i have seen a JL sub blown. not worth fixing buy a new one the cost is not that much more repair on them is 250 - 450 depending on how bad it is and only JL can do the repairs as they dont authorize repair shops access to their voice coils. however i can sell you a new sub with full JL factory warranty drop shipped to your door for about 475$ or I could do you a way better sub ( the baddest competion sub made in the last 5 years) an olympus 2412 dual 2 ohm 5000 watt monster that has user replaceable voice coil options and is killing the competition circuit right now for about $275.00 shipped. it will stomp 2 13 w7's into the ground all day long. 2 subs vs just 1
Sep 17, 2008 | Jl Audio 12W7 Car Subwoofer
Jl audio 12w3v4....both smoked and fried on a 500/ jl amp
Unfortunately, it sounds like the voice coils burnt up. There are places that do repair, but for these particular subs, it would be more cost efficient to replace them. I also doubt they are salable, but ebay is a magical place.....
Mar 05, 2008 | Jl Audio 12W3 Car Subwoofer
Jl Audio 12W7 Car Subwoofer Logo
163 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
