Question about Garmin GPS
I have a garmin nuvi 260W Today it was working fine then suddenly garmin usa screen asking what country came up and all of my information was gone. It was fully charged. Plugged into my car. I reentered the address I was trying to find and a few minutes latter the same thing happened. It has never been dropped or exposed to water or electrical currents. I stopped in Best Buy and they said sorry don't kinow. I am a stroke patient and depend heavly on my GPS. I have only had it since 6/15/2008.
  • Garmin Master
  • 2,124 Answers
This is definitley a problem. This is basically a factory reset happening over and over. It could be a bad connection inside the unit, like a bad solder joint on a component or something wrong with the CPU or supporting hardware. If it's under warranty then please call Garmin, explain the problem and request an RMA number. Make sure it's registered with them before you call. It will speed up the RMA process.
- Jim
Posted on Sep 17, 2008
Hi - I own a Garmin Nuvi 260w. Is it possible to use the SD card to download a trucker navigation road map and upload this to my Garmin Nuvi 260w? Thanks for your response.
It is possible as long as the map is Garmin compatible.
However even with a trucker navigation map installed, the nuvi 260w will not function as a trucking GPS as the routing and IQ of the nuvi 260w does not have the capability to operate in this manner.
The nuvi 260w does not have a trucking mode to allow for the input of specific truck information like truck and trailer length and gross vehicle weight to use as factors on determining the best route for the specific truck/trailer combination.
I would recommend using a GPS specifically designed for trucking like the Garmin Dezl.
http://www.gpscity.com/garmin-dezl-560lmt.html
Sep 10, 2011 | Garmin nuvi 260W GPS Receiver
My 260w has a screen lock and it has no reset button! what's the fix?
To reset the Garmin satnav you power on while holding the bottom right corner of the screen until it asks if you want to reset it.
Jun 12, 2011 | Garmin nuvi 260W GPS Receiver
Nuvi 260w, need support on how to calibrate screen.
Garmin unit do not have a calibration feature so if you are noticing screen issues give the unit a firmware update using garmins web updater software it can be obtained here from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 260W GPS Receiver
My Garmin GPS 260w Givin me Problems
Make sure that in the settings under maps you have the mapsource maps checked rather than unchecked. might have accidently got bumped.
May 04, 2010 | Garmin nuvi 260W GPS Receiver
When I turn on the Garmin 260w, it takes me to the screen that says, "No detailed maps found that support routing. The nuvi cannot be used without them." It will not let me proceed. I have had no...
You may need to reset your unit. You can contact Garmin customer support at 800-800-1020. They will talk you through the reset steps for free!!! Good luck! PS - wait time on hold can be long but worth the free fix!!!
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Jun 01, 2009 | Garmin nuvi 260W GPS Receiver
My screen will always states "acquiring satellites"
Have you updated your Garmin in a while? To update it you need to download their Webupdater program from their website.
From here follow the instructions. A simple update of your GPS may fix this problem.
May 20, 2009 | Garmin nuvi 260W GPS Receiver
Memory card, how does it work and what for?
The SD card slot is there to allow you to expand the memory of your unit so you can play more music files or store more pictures.
It can also be used to add additional map files to your Nuvi. Like if you wanted a map of France, etc.
There is only so much memory on your Nuvi. The SD card slot allows you to expand the memory.
- Jim
SHARCNET-USA
Apr 10, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi GPS 260W not working
A file is probably missing or corrupt in your Nuvi. You can call Garmin at 1-800-800-1020 and their software techs can remotely connect to your computer to check the files on your GPS to see if they are ok or not. There is a method where they create a file with your 25 digit unlock code in a certain directory to unlock the maps, but that information can only be received from Garmin.
Jan 20, 2009 | Garmin nuvi 260W GPS Receiver
I just turned my Garmin nuvi 200 on for the first time, and it came up for what country, and picked the wrong country, I want The USA for my country, and wright now its showing some other language. ...
What you want to do is a factory reset to clear the user data.
1. Turn the unit off.
2. Place your finger in the lower-right corner of the screen.
3. Keep your finger there and turn on the unit.
You will be asked if you want to erase all user data. Select yes. Your Nuvi will restart and ask you the country information again.
- Jim
SHARCNET-USA
Dec 14, 2008 | Garmin GPS
GPS Logo
67 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
