Question about Dryers
No heat frigidare dryer - Dryers
  • 550 Answers
Most common cause of no heat is a blown thermal cutout, over temperature cuthout, thermal fuse (any of a dozen or more names for the same article
examine the exhaust vent ducting inside the dryer for screw on device that looks like this no heat frigidare dryer - 33e786e.jpg or this 843ac7d.jpg, with wires on the terminals. they are not resettable but they are cheap. despite the large number of dryer models there are only a few cutouts, used in multiple dryers, the local parts guy will be able to match it easily.
test with battery annd bulb, or ohmmeter
conducts-good, no conduct- replace
Posted on Sep 17, 2008
My frigidare heavy duty crown series gas dryer is n0t heating and barely able to dry my clothes--what could be the problem and how can i fix it
Hello Chuck, thanks for your inquiry
Based off the information you have provided I have identified a few possibilities as to why your dryer is not heating could be the element, thermostat, or control panel. Each component controls the heat within your dryer and if one goes out it is possible that can cause the rest to not function properly. To accurately find out the reason to why your dryer is not heating I would recommend having a professional come out. Hopefully this is helpful. -Matt
Sep 28, 2014 | Frigidaire Dryers
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 09, 2012 | Frigidaire Electric Dryer
Frigidare gallery not heating. possibly heating element is gone out how hard is it to replace
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 01, 2010 | Frigidaire FER231A Electric Dryer
We have a Frigidar Gallery dryer. The across the
they tend to get hot but excessive heat I would contact a reputable appliance repair and ask them also how old is dryer I do not know if they are still being made Gen.Motors sold them off 30 yrs ago
Dec 18, 2009 | Dryers
My Frigidare gas dryer is making a noice, doesn't heat and leaves a burning smell on the clothes?
everything your saying is conclusive of blocked or reduced airflow. Here is a website to help you and walk therw the issues you are having.
http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
Oct 22, 2009 | Dryers
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
My frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Mar 15, 2009 | Dryers
Put heating element in a frigidare dryer model gler341as2. will not run.
You will have to unplug dismantle and retrace your steps, it simply seems that one of your connections hasn't been completely made.
Jan 13, 2009 | Frigidaire GLER341A Electric Dryer
Replaced heating element in dryer. will not run.
You have a bad (thermal limiter). It's like a fuse one time shot, it stops all of the control power to the dryer. Try testing it with the dryer unplug use a ohm meter across the leads. It should read some type of a reading, if it reads OL it's burn out.
Dryers Logo
67 people viewed this question
Top Dryers Experts
