Question about Yamaha HTR-5940 Receiver
Xm radio I have a strange problem with my XM connectivity, after a couple of months of proper service, my XM radio now will only connect erratically - meaning if the unit is turned off, it may or may not come back on despite it being warm or cold. Sometimes it will immediately return and sometimes only after a few days? The message is No Antenna Connection - but nothing has changed. I have tried tracing the antenna connection and wire but have found nothing wrong. Any ideas on this???
    Scholar:
  • 150 Answers
Try with a different XM Antenna from a friend or shop if possible to verify whether it's the antenna or the unit itself.
Visually inspect antenna cable and connection at the antenna and the unit and make sure the antenna cable hasn't been damaged.
I would do this before considering other options
Good Luck!
Posted on Jan 17, 2010
Xm radio not working
no year, stated., so no real help.
get it serviced.
or check all fuses and connections to it, then get it serviced
the magic xm is busted.
Apr 07, 2014 | Suzuki SX4 Cars & Trucks
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
When my receiver is plugged into my boom box, I get a display reading "check cradle for power"
It's not receiving enough power from the boombox so the voltage drops too low for the receiver to function properly. Check the cradle connector for bent or pressed pins and the power source of the box for proper functioning: measure the voltage it delivers and the status of its components, especially the filtering capacitors.
Jul 04, 2011 | Delphi Roady XT XM Radio Receiver
Cant get xm weather on garmin 740s
To receive XM weather or audio, the GPSMAP 740s requires a GXM 40 Smart Antenna with XM subscription.
The GXM 40 Smart Antenna (010-00730-00) is used to receive weather and audio service from XM satellite radio. For details on XM services please visit our XM webpage.
Once a GXM 40 Smart Antenna has been connected to the GPSMAP 640, the device can display the subscription information for the antenna.
From the Home Page in Boating mode:
  1. Select Configure
  2. Select System
  3. Select System Information
  4. Choose Weather Subscription
From the Home Page in Driving mode:
  1. Select Tools
  2. Select XM Services
  3. Select XM Radio
  4. Set the channel selector to channel 0
  5. Select Radio ID
The subscription information will now be displayed on the screen.
Mar 26, 2011 | Garmin Gxm 51 Weather And Audio Xm...
I have a Alpine CDA-9884 car stereo equipped with XM. It has worked perfect for the last two years. Today, it lost its XM capability. It no longer has XM when I press the source button. Started when I...
XM is provided free at acquiring the systems expexted to remain fucntional for a year until user subscribes to sustain the experience thereafter. Contact the installation technical facility also to ascertain that anyy malfunctions may not have occured with device before attempting to re subscribe to xm radio. Once confirmed regular ssytem funcionalities, additional features are availbel for upgrades for user experiences.
Jan 29, 2011 | Alpine CDA-9884 Car CD/ MP3 Player
XM radio ''NOT READY'' message
I have had this problem at least a half-dozen times, and the simplest solution is to pull the 2 fuses labeled 'audio 1' and 'audio 2.' It resets the radio, but it will work for a while after that (until I have to do it again). Had the xm unit replaced 3 times, new antenna installed, replaced the antenna connection wire - it always dies within a month.
Sep 24, 2009 | 2008 Hyundai Veracruz
XM Radio online use problem
Yeah use sirius radio service. Prolly a reason that it isn't running it anymore because Xm and Sirius merged company's. So Sirius is the same as Xm now.
Jan 09, 2009 | Audio Players & Recorders
KDC-MP532U (Lost ESN # ??)
That will be a problem with the XM box you connected to it, call xm see if thay can help, the radio is just liike a screen for the XM nothing more the box controlls all of it.
Don
Jul 09, 2008 | Kenwood KDC-X590 CD Player
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
Yamaha HTR-5940 Receiver Logo
142 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
