Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Xbox 360 wireless adapter
Hi
ok this is the problem. My wireless adapter is not passing the IP test, but i noticed that if i removed the WEP security key from my router the adapter connects fine. so to resume this and make it clear
WEP-NOT ENABLE= wireless adpater gets IP from router
WEP- ENABLE=wireless adpater does not get IP from router
FYI- DHCP is enable on both scenarios
  • Colton Gilbert Sep 27, 2008
    that is all you have to do is take the WEP key off your Router then connect from your xbox's adapter and connect with no security!!!!!
SOURCE: IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Posted on Sep 26, 2007
SOURCE: xbox 360 wireless networking adapter
it has to be the adapter when i plug in my friends working one it works just fine... i have now gone thru two of them and both of them show a steady red light and my xbox 360 says there is no wireless mode.... when pluging them in to my laptop it says they their info and everything so there shouldn't be anything wrong with them
Posted on Jun 27, 2008
geraldo14200
  • 48 Answers
SOURCE: Can't Connect to XBOX 360 to 128bit WEP Network?
Why not use 64 BIT?
Posted on May 14, 2009
SOURCE: (2) xbox 360's in same home; 1 wireless adapter, other ethernet
you need to assign a static ip address to each inside your router they are more than likely using the same ip address
Posted on Jul 04, 2009
bilink
  • 128 Answers
SOURCE: My wireless adapter for my xbox 360 stays on red light
You can try fixing this using Xbox360 repair guide that covers almost all xbox 360 problems, you can get a copy from here
http://xbox360repairguide.com
Posted on Jul 14, 2009
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
Don't know my WEP key
Often times the WEP key is the serial number printed on your router. If that doesn't work, log into your router through your web browser (just type the router's IP address into the browser's address bar and then enter your username and password) and under Wireless Settings or Security Settings or something similar, you should be able to find the WEP key.
May 28, 2010 | Microsoft Wireless Network Adapter Xbox...
Having problems setting up my wireless networking adapter
What is the brand and model of your wireless router?
We need to know the settings (SSID, wireless security, security key/code) on the wireless router to match the settings on your xbox wireless adapter.
On your XBOX, go to System, then Network Settings, then select "Edit Settings".
Select the wireless network name or SSID of your wireless router. For the network mode, select Infrastructure. Select the security type if WPA or WEP and enter the Passphrase or WEP key.
Save the settings then select Test Xbox Live Connection.
I hope this works! Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated. Good luck!
Feb 14, 2010 | Microsoft Wireless Network Adapter Xbox...
What are the steps to hooking up your xbox 360 wireless network adapter
Hello
Plug the wireless USB adapter into the USB port on the back of the Xbox 360 console.
Turn on your Xbox 360 console.
The console will recognize the wireless adapter and will walk you thru the wireless network setup. Be sure to have your WEP key (if encryption is used) for your router before you start this process.
This adapter works well - I am using one and regularly play Modern Warfare 2 with multiple chat sessions. There is no noticable difference between my wired network connection and this wireless network connection.
Happy gaming!
Dec 02, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I got a new xbox 360, and i need to connect my xbox back
you need to go to your xbox settings and your network settings, find your network and put in the wep key for your router. If you don't know your wep key for your router, the easiest way to find it is to go on your computer, open a browser of some kind (e.g. internet explorer, firefox, safari etc.) and type in the ip address. The most standard ip address is 192.168.1.1 or something close to that. It should bring up the settings for your router and you can find the wep key usually under the wireless tab and then wireless security and your wep key should be right there! enter it into your xbox and have fun gaming. =)
Jun 16, 2009 | Microsoft Wireless Network Adapter Xbox...
Cannot connct xbox 360 wireless adaptor
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Jan 05, 2009 | Microsoft Wireless Network Adapter Xbox...
Wep address
Your wep adress? You mean your IP adress? Go to http://whatismyip.com/ and that number is your IP adress. Enter that manually, and your XBox should be connected.
Jul 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: 10.0.0.150 (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask: 255.255.255.0
      • Gateway: 10.0.0.2
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server: 10.0.0.2
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type http://10.0.0.2 in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: 10.0.0.150 (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
