Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer stopped working
Did two loads of laundry fine today. The third load filled the tub and now no response from washer. When pulling knob there is no response. Slight smell , such as something overheated.
Any suggestions
  • 116 Answers
If after waiting for a while it still does not respond - most likely the motor is burnt - especially if those were all very heavy loads
Regards
Posted on Sep 20, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
The machine suddenly "clicked' when I took laundry out and seems "dead"- Is it switch possibly pannel switch that stop working? When I rrotate knob and pull it out- no response- no electricity and no...
The control board went bad. Your switch went bad or you blew the fuse. All are located behind the knobs. Just remove the knobs and undue the screws up top. Make sure to unplug the system before opening it up
Jan 02, 2010 | Maytag PAV2300 Top Load Washer
Keeps on filling and wont drain
please follow the steps which i give to find and rectify the mistake (1) First check the wash load/laundry. If it is unevenly distributed in the tub making it unequal, rearrange it, close the lid again.
(2) Make sure your washer is leveled and you have filled sufficient water in the tub for that size of wash load/laundry. Insufficient water can make imbalance.
(3) Make sure the power cord/cable is plugged into the working electrical wall socket.
(4) It is better to check the appropriate circuit breakers or fuse of the fuse box and reset if necessary.
(5) Inspect the drain hoses and remove any bends. Inspect the drain system, too - if it's clogged.
(6) Then close the washer lid and pull out the knob to start it. For your safety, the washer will not spin unless the door is closed.
(7) Excessive foam can also cause this problem. If you find it to be the solution, rewash the clothes with plain water. For future, ensure use of correct amount of detergent with low-foam.
(8) It is possible that the lid switch, that prevents the washer from spinning when the lid is open, could be malfunctioning. If that happens, a built-in mechanism – brakes will be applied and washer will stop washer operations until the lid switch is repaired/replaced.
Jun 13, 2009 | Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
Very LOUD 'banging' noise.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 20, 2009 | Kenmore 41042
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
