Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Electrical problem with mower
The engine starts fine, but when I try to disengage the clutch or try to engage the blades, the engine shuts off. The problem appears to be electrical in nature. Possibly a short?
  • dougrad Sep 17, 2008
    My Craftsman lawn tractor has the same problem. It stalled while I was mowing last night. It restarted just fine, but when I released the park brake it stalls out. I'm thinking I may have an interlock switch with a loose wire?
  • 53 Answers
Deffinatly the seat switch if the wires are green you can cut one if they are black you can tie them together this will bypass the switch for testing only
Posted on Jun 12, 2009
  • 15 Answers
The Oddest has it right! Usually these problems fall under "electrical", and in this case, the kill switches. Usually always the same, you have the generic 3 (sometimes more), and with each brand, they are different, in different PLACES, but do the exact same thing:
Grounding the electrical, to kill it (when open), and allowing it to run (when closed), or vice versa! What Oddest suggested applies to ANY riding mower, the only difference is WHERE they are, and HOW MANY and HOW they open/close.
Gotta love technical engineering simplicity at its' finest!
Posted on May 29, 2009
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 142 Answers
Try checking out where these parts connect. There is usually a switch that must connect in order for the particular item to work correctly, i.e. the seat, when sat on, provides a complete connection in order for the lawnmower to run. Sometimes, all you need to do is clean the contacts, and double check the wiring to it, to make sure these are secure or not eaten through. You can use a shot of WD-40 to clean these and it should be fine.
Posted on Sep 20, 2008
When i engage my blade on a cub cadet it will not engage
Posted on Oct 18, 2008
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
PTO will not disengage ! Blades are engaged while switch is pushed in or off
you have a broken spring in the pto clutch the only fix is to replace it the clutch should cost around two hundred dollers or you can unplug the clutch and plug it in when needed
Aug 15, 2014 | Garden
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Bracket clutch anti-rotation
Without the anti-rotation arm installed when you engaged the PTO the clutch spun and probably ripped out the wires connecting it to the harness. This can be repaired but is tricky. If you have a Husqvarna dealer close by, it will save you several hours of labor to have them correct the problem.
Mar 07, 2017 | Husqvarna Garden
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
Husqvarna pto problem(?) disengaged blades to travel, would not engage after. Battery dead when checked after shutting off engine and wouldn't restart
Hi, first charge or replace the battery if necessary then check that the mower is charging the battery. The pto is probably fine but it needs battery voltage to engage. If the mower has stopped charging the battery may have had enough voltage to hold the pto in until you disengaged it but not enough to re engage it. Regards Phil.
Sep 06, 2012 | Garden
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
533 people viewed this question
Top Craftsman Garden Experts
Dwain Pippen
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
