Question about O2 Xda Atom Exec Smartphone
O2xda Problem When i switch on the phone,my O2 phone appear please tap the screen to align the screen. i tap the screen many time,but cant't work. how?
  • edi007 Jan 10, 2009
    hey i have same problam i want to tap on my touch screen it will not working i dnt no why pls if u have any solution for this thing pls send me ur advice on this mail id edi.axe2@yahoo.ca or aditya.verma@mail2web.com
    thanks
  • Anonymous Feb 02, 2009
    I am getting Tap the scree. but not working properly
  • 178 Answers
Your touch pad might have gone bad/malfunctioning.
Sorry
Please rate!
Posted on Oct 30, 2008
My asus p552w has align screen problem... when i enter this option it doesnt come out of it... just that target moves when i click/tap on it... it was getting clicked on right portion of the screen only so...
Hi Prash,
The solution is simple. Please tap the screen exactly in the center of the '+' sign that appears on the screen. The + sign or the target keeps moving till the screen is not alligned. I faced the same problem and searched and found your query on many forums but no luck. So I actually resorted to aiming the target with one eye closed...and the damn thing worked in one shot.....Now my default settings have been installed. Lets see what is in store on the other side of the default installation.
New Asus P552W user!
Nov 17, 2009 | ASUS Computers & Internet
ALIGN SCREEN
please explain what you are doing with the alignment screen. Have you done the 5 point alignment method? have you confirmed it? if it cannot confirm your alignment and it is going back to the first step again, you need to change your touchscreen module.
Aug 27, 2009 | O2 XDA Mini S Smartphone
The align keeps on and on
You should align your screen by tapping each time (Just tap a bit carefully and with a little bit more pressure) that cross shows up during the setup process. It should take 4-5 steps and at the end you can follow the other setup instructions. Hope this helps.
May 17, 2009 | O2 Xda II mini
I have a tmobile wing the phone works fine but the touch screen does not work. i got the phone from someone and when i switch the sim cards it went to the screen that says to taap it to align the screen..i...
All you have to do is tap the screen with the stylus (slim pen that is position on the bottom right side of phone) where ever you see ( + ). Follow the plus sign ( + ) where ever it is on your screen. It should go in 5 different directions on the screen before it prompts you to the next screen. This process is mostly needed for hard reset (starting from original factory settings) or if you need to align the screen with the stylus.
Please make sure while performing the aligning task to tap the center of the (+) as possible. Not doing so may result in a poor functioning screen.
Mar 02, 2009 | T-Mobile Wing™ Smartphone
Align screen problem
plz plz plz help my problem with O2 XDMini s wen i torn on is say windows mobile tap the screen to set up your windows mobile-based device then wen i toch the screen crosor coming up its like thes all the time plz plz if anyone can help moha.5838@hotmail.com thanks
Feb 08, 2008 | O2 Xda II mini
Screen
your touch panel could have died and you may need to replace it. i would try updating the firmware too that fixed a similar issue for me
Nov 08, 2007 | O2 Xda III
RESET phone solution.. pls help..
hi,
   u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Oct 22, 2007 | O2 Xda Trion Smartphone
Screen tapping is not working
have u tried "screen alignment" menu for configuration
Jul 08, 2007 | O2 Xda II mini
My O2 mini screen tapping not working, when i tap nothing works. my o2 says "device locked", i am unable to use the keyboard also to acces my data as well as even making outgoing calls. please help!!!!!
This one is an easy one to solve. Much like with the other mobile phones there is the option to lock the device to prevent it from activating programs whilst it is in your pocket. Simple push the power button once to reveal the screen and at the bottom left corner there is a button called "Unlock". Once you click this another screen will appear with another button called "Unlock". Click this and your phone will be unlocked.
Sep 23, 2006 | O2 Xda II mini
O2 Xda Atom Exec Smartphone Logo
116 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
