Question about Epson Stylus 680 InkJet Color Printer
Print in black ink only
How do I set up my printer to only print in black ink because my color is almost out and won't print anything. I know I have enough black ink because I just replaced it 2 weeks ago.
  • 52 Answers
You can try by going into the printers options from the control panel "Printers and scanners" then right click the printer you are referring to and click on "printing preferences"
Click the Tab "Color"
and Check the "Print in greyscale" box and apply
Please rate
Thanks,
Nick
Posted on Sep 17, 2008
My printer will not print anything. I have a full cartridge of black ink, but low on the other colors. Will it not print with the colored ink out?
Assuming the test print page prints using the black ink, printers have a setting that allows you to select black and white printing. If you need further help you need to include the manufacturer and brand of the printer. If the test page doesn't print the black ink and Since you say you have a full black ink cartridge I would also check that you completely removed the plastic tab/sticker that covered the hole the the inks comes out of and that the ink cartridge is securly installed.
Dec 06, 2016 | PRINTER Office Equipment & Supplies
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Why won't my Lexmark 5600- 6600 Series Printer print in color?
It could be the print setting on the application where you're printing from. Before you send your print job and hit "Print" button on your computer, check in the Printing Preferences and make sure it is not set to print "Using black ink only.".
Mar 06, 2012 | Lexmark Office Equipment & Supplies
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Can't print in black and white
Hi Aaron,
There should be a setting in your PREFERENCES that allow you to set it to black print only. Select it as your default setting so that you don't have to change the settings each time you print.
Hope this helps. Good luck!
Jul 31, 2009 | Office Equipment & Supplies
My printer has an almost full black cartridge but will not print.
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
May 31, 2009 | HP DeskJet 932c InkJet Printer
Is there a setting to print in B/W only?
Yes
When printing press file,then print, from there select printing preferences go over the pages and look for black and white setting or grayscale setting.
it will print in black and white only.
May 29, 2009 | Office Equipment & Supplies
Cannot print in color
need head cleaning , check your option color or black , adjust in maximum color , mostly some printer there many option.
Dec 14, 2007 | Lexmark X5150 All-In-One InkJet Printer
Epson Stylus 680 InkJet Color Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
