Question about Epson Stylus CX6600 All-In-One InkJet Printer
No ink = useless machine???
I found this old printer and was wondering if any of the other functions work without the ink cartridge being full (ie. scan, use the memory card reader, fax)? Seems like I'm out of black ink, but I don't want to print anything... I just need the scan and memory card reader function. Is this a piece of **** junk without the ink in there? Please let me know.
  • DoubleTime33 Sep 17, 2008
    oh... just in case, I'm talking about the Epson Stylus CX6600
    Do i need a special software in order to do the rest?
    Scholar:
  • 97 Answers
I used to have one of these printers and it should work fine without any ink. You might wanna try and put in a cartridge though but not necessarily a new one. All of the other functions of the printer should work just fine. On the question of needing a special software, the answer is yes. You can download the drivers and software that is needed from the EPSON website or just simply click on this LINK.
Posted on Sep 17, 2008
  • 52 Answers
It should not need ink to scan / fax/ use the card reader. it just wont print :)
please rate
Thanks,
Nick
My Brother MFC 440CN will not recognize a Brother
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Jan 23, 2010 | Brother Office Equipment & Supplies
Mfc 440cn printer says 'ink empty' to new full ink cartridge
Jan 19, 2010 | Brother Office Equipment & Supplies
Can't scan when of Ink! What is the small black cartridge for?
You must have ink installed to scan.
Small cartridge is a print head.
Jan 26, 2009 | Canon PIXMA MP610 InkJet Printer
Brother MFC-210C does not reset after ink is replaced
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and probably other similar printers in the MFC range.
Nov 21, 2008 | Office Equipment & Supplies
Brother mfc215 printer, machine keeps telling me that I have an empty Black ink cartridge , when I check it is over half full
Are the sensors that read the ink level clean?
Oct 07, 2008 | Office Equipment & Supplies
My printer (brother mfc-210c) says that the 4 ink cartridges are empty but i have recently renewed them. (about a month ago. is thee any waY TO FIX THIS AS I CANNOT PRINT ANYTHING
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. Read the manual, it tells yu the procedures to reset certain error messages. But if the circuitry on the machine itself is faulty it wont fix it.
Jul 16, 2008 | Brother Office Equipment & Supplies
I have just installed a black cartridge in my Brother MFC-440CN printer and on the small screen it says "ink empty-black". What could the problem be?
It could be just a faulty cartridge, but try turning off printer at power point, leave 5 to 10 minutes and turn on, alternative is remove and replace cartridge or return cartridge to shop you bought it from and get a replacement. Industry standard for OEM cartridges is 2% failure rate!!!
Jul 03, 2008 | Brother Office Equipment & Supplies
Have a mfc-210c brother ink empty cyan replace ink. have put in a new lc41y ink cartridge . machine says open cover and reinstall ink cartridge. sortof done this 20 times!look forward to some advice...
May 03, 2008 | Office Equipment & Supplies
Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Nov 08, 2007 | Brother MFC-5840CN All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
385 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
