Question about RCA HD52W59 HDTV Projection Television
Still won't turn on
Hi, I replaced the flyback, but still won't power up. It made a noise, like a little squeak when I tried to turn it on. Still flashes 9 times, then once. However, when the power is turned on, the power button remains green (just doesn't turn on). Is it possible there is a transistor/fuse that needs replaced? Or do I need to take it back out and resolder it?
  • 1,139 Answers
Hello mdavis111111,
Try to see if the Horizontal output transistor is shorted to ground by checking the resistance value to ground. Also check the Switching power supply Power MOSFET . These are two possible causes for your problem.
I hope this helps,
Thank you,
Posted on Sep 27, 2008
Hi my rca p52937 won't turn on and is making a
The ticking sound is almost always caused by the Flyback and Hot transistor. It could be other items also located on the deflection board but flyback is most likliest. You can get a replacement flyback and Hot tarnsistor from
Jul 07, 2011 | RCA Televison & Video
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Will not turn on
If you replaced the FL231 without replaceing the DL231 it will usually work for a little while then fail. However if the sound youre hearing now is a short sharp chirp which coincides with the power indicator its often caused by a failed flyback and HOT Transistor, if the sound sounds like a soft psssst three times then DL030 and DL032 all items are on the Deflection/power board.
Jul 18, 2010 | RCA D52W19 52" Rear Projection Television
1995 Jeep Grand Cherokee squeaking and power steering
It very well could be the pawer steering pump. But to isolate the squeking sound, take that can of wd-40 and find the idler pully and tensior pully. Spray the bearing area of both pulleys. If your bearing in those pulleys are going bad then it will make that noise. If the wd-40 quits the noise at one of those tow pulleys then you know which one to replace. If its does not, then start looking to replace the powersteering pump. I take it you have checked the power steering fluid levels and they are ok?? Also, you stated that the noise started after you bought the alternator, then try a new alternator. It might of just been a faulty alternator. Happens all the time. One last inexpensive tip is replacing all belts with new. Belts get glazed over and dirty and cause noise too. One last question. Did you make sure the belts were tight enough? Just a little variance in the belt tension can make the difference.
Aug 07, 2009 | 1995 Jeep Grand Cherokee
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
Power steering
There is a loud squeak on the front of my 1991 ls 400. The squeak is near the alternator. Any one no what it is?
Aug 15, 2008 | 1991 Lexus LS 400
RCA D52W23
Sounds like the flyback is bad you can get a new flyback number 259296 at the following link and they provide free tech support so you can install it yourself. heres the link.
May 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
The rca television i have just made a weird noise and turned off. now it wont turn on.
can you describe what the noise was with a little more detail. Squealing or a loud squeaking can mean flyback.
Apr 05, 2008 | Televison & Video
My Television makes a weird noise.
hi....maybe theres a problem with your high voltage(flyback)section.or maybe there are still moist inside your tv...try to open it(if you can) and use your hair dryer to dry it....if noise still present after you done the serviceman
Apr 24, 2007 | RCA F36668 36" TV
RCA HD52W59 HDTV Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
