Question about HP PSC 1350 All-In-One Thermal Printer
PRINTTER HP1350 CARTRIDGE LIGHT
PRINT CARTRIGDE LIGHT FLASHING
    Scholar:
  • 73 Answers
It sounds like the printer thinks one or more of the cartridges are empty, even when they aren't.
Your only option would be to purchase new cartridges, install them and see if the light continues to flash. If it does, I would suggest you contact HP:
http://h10025.www1.hp.com/ewfrf/wc/conta...
(You can speak to an online technician, call support, or e-mail them, I would suggest the first option)
Posted on Sep 17, 2008
I have a solid red light on now all the time so i cant print.
Change the toner cartrigde or refill (is easy to refill the toner) and change the cartridge chip.
Feb 19, 2013 | Samsung ML 1510 Laser Printer
I can't print anything off the computer since I put in a new cartrigde.
Now way related to cartridge &Printer driver, check USB cable,reload drivers once again.
Dec 22, 2011 | HP Officejet 5510 All-In-One Thermal...
I have justchanged both cartridges on this HP1350 printer \r\n( 56 and 57) "Check Print Cartridge" light remains flashing. Green E illuminated.Printer not operating.
Hi Jim
Read your question about the printer HP PSC 1350. The possible solutions are as below.....
1. Take the cartridges out from your printer.
2. Now Unplug the Power Cable from the back of your Printer.
3. Now please press and Hold down the Power Button ( On/ Off button) for the next 40 seconds.
4. After 40 seconds, release the power button and then plug in the Power Cable.
5. Now clean the copper connections of the cartridges with a clean cloth and some distilled water. Make sure that no water droplet remains on the copper connections.
6. After cleaning the cartridges, insert the cartridges in to printer and then check the issue.
7. Try to make a color copy and see if everything is going fine.
8. If this resolves your issue, well and Good. Otherwise, try using a different set of Cartridge. Try changing each cartridge one by one and see which cartridge is creating problem.
9. If you still experience the same issue, then there is a problem in the logic card of the printer. It needs repairing or the replacement of the logic card.
Let us hope for the best.
Thanks & Regards
Ashish Rohilla
Aug 21, 2010 | HP PSC 1350 All-In-One Thermal Printer
Printing is blank but I have new ink cartrigde in
The print-head stucks (FIXYA would '****' the preceding word, if I left out the 't') ink from the ink-cartridge, and sprays the ink onto the paper, when the print-head is *NOT* "clogged".
Run a "print-head-cleaning" cycle to "unclog" the print-head.
Apr 27, 2010 | Lexmark Office Equipment & Supplies
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Printer will not print color only black and white. new cartridge installed.
Hello friend,
Recently on the market we are having fake,imitation, compatible cartridge and also faulty cartrigde.
may be this is the problem...
Dec 18, 2009 | HP DeskJet 3650 InkJet Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Flashing green light prevents printing.
hi!!!!
try to pull out the cardtridge and put it back properly
sometime the cartrigde is place properly on the printer!!!
try to email me ronaldsuboc@gmail.com
Aug 08, 2008 | Canon S520 InkJet Photo Printer
Ink cartrigde
Did you remove the protective blue tape from the cartridge bottom, if please clean the cartridge Take a warm, damp paper towel or napkin and gently clean the bottom of the car where ink comes repeat the same process with dry paper towel and try to print , if you still have the problem you can contact lexmark and get the cart replaced with a new one as the cart comes with 6 months warranty.......
Jun 30, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Hp1350
Here is a download link for you printer that includes maintenence procedures DOWNLOAD
Nov 22, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
Seeker5211
Seeker5211
