Question about Refrigerators
Frige not cold
Our fridge is not cooling at all. We have a kenmore side by side. i cant find the model #. The fan is on and the compressor is making noise. The lifgr is on to. I turned up the thermostat thinkinf that would help..it didn't. Thanks for your help! model# 253 546 62405. The frig part does not get cold... spoils food, but freezer works. Been on the phone for hours speaking to the network of Sears/Kenmore Tech's to honor the 5 yr warrantee - free of charge - written in the owners manual and a sticker on the Refrig. I'm second owner, as this is a 2005 model. ( 3 yrs old). Bottom line it will cost me $251.oo to get a Rep to Service this problem --that will buy me the Exxxtended Warrantee which will cover the condensor cost, they said they think thats the problem. $ 75. to do a walk in your door service call to diagnoise why frig is not keeping cold. Or I'll have to pay parts & labor a condensor separtly ....
What part of: 5 yr Warrantee = Free of Charge, in writing does Kenmore/Sears honor?
-First call I got a appt. in 3 weeks - free of charge
-second call - no no, you must by the extended warranty to cover the condensor costs.
any suggestions?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Check in the freezer back wall for frost might be defrost problem or if it has a thermistor it might not be working opening is your freezer 0 or below? 5 year warrant on compressor and sealed system read fine print on papaers if you still have them.may also be in defrost computer board if its a defrost problem
Posted on Sep 17, 2008
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Refrigerators
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Kenmore side by side is not getting cold or freezing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Regards:
VOTIT
Don't forget to rate;
Jul 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
Sep 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refidgerator is not cooling
let fridge cool down it sounds like the relay overload is bad try replacing it with a 3 n 1 start kit directions on the kit real easy to hook up... if the compressor starts then you are ok... hopefully the compressor is not burned out good luck
May 09, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
212 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
