Question about Norcent Technologies DC-520 Digital Camera
Formatting SD card and Picture Error
After trying to change the date on the camera and clicking on format 'YES' and was also experiencing getting the message ' picture error' when trying to delete some existing photos; on returning to view remaining photos they were all not on there for viewing.
Did formatting at that stage affect the photos that were already stored on the camera. Is there any solution to recovering all 100 photos.
    Problem Solver:
  • 14 Answers
I suggest you refer to this article, it tells you how to solve the problem of SD card error and how to get back data from SD card.
Posted on May 17, 2012
    President:
  • 1,114 Answers
Formatting always deletes the entire contents of the card!
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Posted on Sep 17, 2008
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
Canon sx10 when i put in a sd card card error comes on the screen i have tried new card makes no difference. williamberry25@hotmail.com
I don't know if you are aware of an SD card having a protection lock on the side I'll give you a diagram for the proper positioning of this little switch. Also adding that all "New" memory cards need to be formatted to the camera they are being used in. Formatting prepares the surface to properly accept new picture files from your camera also after each download the memory card needs formatting. I'm talking formatting not the delete or delete all buttons, formatting option should be found in your camera set up menus, takes only a few seconds and you are good to go.
Switch Lock Diagram
Jan 30, 2011 | Canon Cameras
I am getting error message that sd card is blank and/or when i want to use my camera error message comes as insert your sd card..i try to format the sd card by following format sd card section but nothing...
Try formatting your SD card by plugging in Laptop's or using a memory card reader. Don't use the cell, after formatting insert in cell and re-format. it will work.
Nov 10, 2010 | Sony Ericsson XPERIA X10 Cell Phone
My sandisk sd card isn't working in my camera. My camera is a vivitar 5024 camera, everytime I try to take a picture it says memory card is not ready, it says switch to internel ram. This memory card is...
Have you tried to format the card.
1.
  • Start up a computer with Windows XP, Vista, windows 7or Insert the SD card into an external memory card reader or into the computer's built in card reader. If it the first time a SD card has been inserted into the computer, Windows will recognize the SD card and automatically install drivers to read the memory card.
  • 2Go to the computer view by clicking on the windows start menu icon in the bottom right corner of the computer. In Windows 7 and Vista click "Computer". In Windows XP click "My Computer"
  • 3Right click on the SD drive under the computer heading. A dialog box with different options for the drive will appear. Click on "Format" to bring up the formatting dialog box.
  • 4Select the type of formatting (also known as file system format). In Windows XP or Vista there are several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added choice called exFAT formatting. This is an improved FAT formatting type with improved meta data capabilities. Choose the formatting type, name if the drive if desired, check or uncheck the "quick format" option, and press the "Start" button. When the SD card format is complete Windows will provide a notification.
    If you need further assistance please feel free to let me know. Thanks and have great day, Midwest-tek
  • Aug 31, 2010 | Vivitar ViviCam 5024 Digital Camera
    How do i format my sandisk in my panasonic lumix FX40
    Hello :
    1: Insert the SD card into the multi-card reader on your computer. Most newer personal computers and laptops come with a multi-card reader. If you don't have one , then you should get one ! Just make certain that you insert the SD card into the appropriate slot. A multi-card reader picture is shown : There another types of multi-card reader , so you can choose the best one for you .b74156b.jpg
    2: Right click once on the Windows "Start" button.
    3: Click once on the "Explore" option.
    4: Find the SD card in the "Folders" section of the window.
    5: Right-click once on the SD card icon.
    6: Click once on the "Format" option.
    7: Make any desired changes using the options on the "Format" window. Default options are recommended, but it is possible to change the file system and allocation unit size. If you change any of these settings and want to change back, click once on "restore device defaults." To perform a quick format, click once in the "Quick Format" box. A quick format means only that all files will be removed from the SD card, but it will not be checked for bad sectors. A quick format is considerably faster than a full format, but neither takes too long.
    8:
    Click once on the "Start" button on the "Format" window to begin the formatting process. A warning window will pop up to make certain you want to proceed with the formatting of the SD card. Click one on the "Yes" button to move on.
    9:
    Click once on the "OK" button on the "Formatting" window that pops up when the formatting is complete.
    10:
    Click once on the "Close" button on the "Format" window to exit the formatting process.
    good luck .
    please don't forget to rate !
    Apr 04, 2010 | Panasonic Lumix DMC-FX12 Digital Camera
    SD Card (2GB YES Make) Gives Formatting error
    If you have a card reader or a printer with an SD card slot in it, try formatting the card or deleting all files on it using a PC. My laptop has a slot built-in I'm able to use. Check out your options. Try formatting it outside of your camera. I've heard of some card swapping between brands of cameras doing crazy stuff as you are experiencing.
    Jan 07, 2009 | Kodak EasyShare C315 Digital Camera
    D900 mp3 problem
    Just try formatting the SD card. Hope it works fine.
    Just connect the micro SD with computer.(You need SD adapter, SD card reader, and USB connection) Most computer will recognise the SD card automatically. Format the micro SD in the Window Explorer(or My Computer). Format menu can be found if you click right-button with cursor on the drive letter. After formatting, re-insert micro SD into your D900.
    Some Korean experts says the problem might be caused by different file system (e.g. FAT, FAT32, etc) in each memory card. So they recommended not to share your memory card with different mobile phones as well as any electric devices (eg. MP3 player and digital camera).
    Nov 24, 2008 | Samsung SGH-D900 Cellular Phone
    Card error message during formatting XD picture card
    The max card size for the camera is either M or H512mb. Try the following website to locate cards for sale www.oempcworld.com
    Nov 11, 2008 | Olympus Camedia C-350 Digital Camera
    FORMATTING SD 1G MEMORY CARD
    after you connect the card with pc you will see it in device manager as removal disk.from there right click and click on format.
    yes after formating you can use in camera
    Apr 05, 2008 | Cameras
    Format Memory Card Error
    The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
    Mar 13, 2008 | Kodak EasyShare C315 Digital Camera
    Norcent Technologies DC-520 Digital Camera Logo
    132 people viewed this question
    Top Norcent Technologies Cameras Experts
    vwong
    Level 1 Expert
    Greg Cann
    Greg Cann
    Are you a Norcent Technologies Camera Expert? Answer questions, earn points and help others
