Question about Gemini Sound Products EQ-300 Home Equalizer
Conection i need to know how conect my equalizer to my amplifiers in my dj sistem
Connect the out of your equalizer to your amplifiers in...... thats it................ ok!!!
Posted on Sep 23, 2008
How to conect this device to a computer
Those look like klisph speakers. If so then I\'m jealous. What manufacture? How many watts per speaker and you could use line of sight infrared light wireless transponders, but they have built in amplifiers that normally have to be plugged in to 110 volts ac or household current. Battery powered wireless units are low wattage and not for your 3.1 or 5.1 system shown. Either way. If it was me with this issue, there are several sites with do it yourself tutorials online, search Google, Google knows who knows everything. Or if u have the pretty pennies then you can buy a system but usually between one to three thousand for the extent it appears you have to go.
May 15, 2014 | Audio Players & Recorders
How do i connect the souncard to an amplifier for speakers
To conect a sound card to an amplifier is easy onect the pin to the audio out put of the sound cand and to the audio in in the amplifier and make the selection mode as aux then the sound card will be amplified with amplifier also increse the volume in the sound card to approximate level
Apr 05, 2011 | Numark DJ/iO Sound Card
How can i conect my amplifier with equalizer
I don't know what equalizer you have but, from the head unit RCA output to the equalizer RCA input and then from the equalizer RCA output to the amplifier RCA input. Hope this helps. Without knowing which EQ you are using thats the best I can do. dreamsystems.
Feb 16, 2011 | Kenwood KAC-8401 Car Audio Amplifier
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
How do I connect a Realistic Home Equalizer to a Stereo Home Receiver?
record out to -----------equalizer in-------------equalizer out-----------------to tape in
Sep 13, 2009 | Audio Players & Recorders
I wanna equalizer a jensen 760 but i can`t can you tell me how can i do?
Hello, if you want to put an equalizer on an amp then I would suggest you get a preamp style equalizer, non powered of course, take the rca output whichever one you want to use and conect it to the input on the equalizer. Then take the output from the equalizer and hook it up to the input on your amp. That's it. Most equalizers also have sub outputs, make sure you hook the correct output from the equalizer up to your amp. Also most have 3 outputs depending on the type you have. If you need more help just let me know, good luck
Aug 14, 2009 | Audiovox Jensen Power 760 Car Audio...
Have system hooked up but no power to the amp
check the ground conection and the remote conection if this one is conected to the headunit be sure to have it. if you are using a pre-amp equalizer check the remote conection on it too!!! it maybe the remote from the headunit to the amp or try to conect the remote cable from the amp to the antena remote cable on your headunit.
Mar 29, 2009 | Jensen Car Audio & Video
How I can conect/
1-record out in home theater to equalizer in.
2-equalizer out to playback in in home theater
Mar 21, 2009 | Audio Players & Recorders
Conect eq. with the turntable
hi there, first you have to pit your turntable phono at the pre - amp phono to amplified then after you can put now direct into your equalizer and then to your amplifier
Dec 30, 2008 | Spectrum Technical Hifi EQ-B5200...
How do i conect equalizer
first connect pre-amp out to equalizer in and equalizer out to amplifier in-and amplifier to loudspeaker.
second-mixer out to equalizer in and equalizer out to amplifier in and amplifier out to speaker.
Jun 15, 2008 | Audio Players & Recorders
Gemini Sound Products EQ-300 Home Equalizer Logo
131 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Don Hart
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
