Question about Acer Aspire 3050-1733 Notebook
Doesnt charge When i tried using the adapter, it does not charge my computer, the wire does indeed work but laptop doesnt charge, is this a battery issue, or can it be something else?
    Scholar:
  • 97 Answers
This could most probably be a battery issue. To check if it is really a battery issue, remove the battery and plug in the AC adapter. If the computer powers up, then this is definitely a battery issue and you'll need to purchase a new battery or call your computer's manufacturer and ask them if they have battery exchange programs.
Posted on Sep 17, 2008
Battery not charging
this is just a suggestion not an appropriate answer
just try this!
try to unmount the battery from laptop and connect the battery, then mount the battery back to laptop
then leave the laptop goes off with out power then connect the adapter back to laptop and try to on normally.
Apr 17, 2013 | Dell Inspiron 1318 Laptop Computer PC...
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
My battery was low and I plugged it in to charge it. For some reason it won't charge or work. I was in the middle of searching google when the battery died.
Remove the battery and try starting the computer with the AC adapter.
If that starts up, reseat the battery and u are good to go.
If it doesnt, try checking the computer with a different adapter.
Nov 25, 2010 | Acer Computers & Internet
I have an compaq presariov2000 laptop. the problem is battery not charging and the charging symbol is also in a hide and seek mood. I also try scan for hardware changes method but it won't work. plz help.
go to compaq's website, download the latest Bios Update, run the bios update while the power suply is connected on the laptop. after the update, the power adapter should be recognized by the laptop
Sep 07, 2010 | HP Compaq Presario V2000 Notebook
It just wont turn on i have checked the power lead and its ok its an acer aspire 5050 laptop
Hi. I would suggest you double check the ac adapter if the powercord is properly attach to it ot also you might want to try powerdraining or powercycling your computer. To do this you must turn off your laptop then remove the battery and unplug the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and try turning on your laptop, if this doesnt work then try power draining it again and just use the ac adapter or just plug it in without the battery then try again turning it on. If it still has the power issue then try a known good ac adapter so that you could double check that it is not an ac adapter issue or a battery issue. If all that trouble shooting step doesnt work then you could also try calling acer tech support to help you on your issue if your machine or laptop is still under warranty they would help you fix it by sending that laptop to there depot without any charge. Hope this Helps
Jun 09, 2010 | Acer Aspire 5050-3242 Notebook
My emachine d620 laptop will not power on. the led light is green and the battery is charged. the power button is not working.
Hi. I would suggest that you powerdrain your computer might fix this. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. If this doesnt work try to powerdrain again the laptop then just use the ac adapter to turn on your computer and that is without the battery. Hope this helps.
Jun 03, 2010 | eMachines eMD620-5133 Notebook
My laptop touchpad doesnt work properly when i charge my laptop.
If your new adapter is not compatible with your Acer Aspire in voltage and current, your laptop maybe can't work well. Check your new adapter and ensure if it is the same with the original adapter.
Apr 17, 2010 | Dell F3534 Touchpad
Battery won't hold a charge and AC adapter is not recognized to run computer
As per the description it seems the problem with adapter. Try using another adapter and keep the laptop for charging for few hours and check the battery. If this doesnt solve the issue please mail back.
Dec 01, 2009 | Acer Aspire 5610-4648 Notebook
Charger isnt recognized
Dell portables use a sensing wire in the barrel of the adapter plug to determine the wattage of the ac adapter. If that fine wire in the center of the plug is bent or broken, the system cannot ID the adapter and the battery charger is disabled.
SO, first try a known good AC adapter for a D-Series Dell (You might be able to check with Geek Squad at a local Best Buy if you don'e have access to another ac adapter) If a known good ac adapter works, then replace the ac adapter.
If a known good AC adapter does the same thing then the fault is in the charging circuit of the motherboard and the motherboard will need to be replaced.
Oct 03, 2009 | Dell Latitude D600 Notebook
Hp 530 notebook will not charge
I bought a new battery...and it STILL doesnt charge!!! Any suggestions?
Aug 24, 2009 | HP 530i (Q6750A) DVD±RW Dual Layer...
Acer Aspire 3050-1733 Notebook Logo
137 people viewed this question
Brian Sullivan
Brian Sullivan
