Question about Refrigerators
Get shock when touch door on a turbo air - Refrigerators
  • hvac99 Sep 17, 2008
    i get a shock when i touch door on a turbo air TSF-72SD.checked volts from door to ground 10 volts.ground to freezer good. disconected door heaters proplem went away. heater is not shorted to ground.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Wall plug could be wired in reverse cause the ground to feed the refrig have you checked it? if not you can buy a circiut tester that plugs in socket and it will tell you if its wired right get it at Lowes for about 5:00 if it was a dead short it would should kick the breaker
Posted on Sep 17, 2008
Just replaced my front shocks last week, but when jacking up rear tires, front shocks dropped to touching the tires again, any others problems?
Are these air shocks? If they are, then the extra weight on the front wheels can push air past the "O" ring in the inlet air fitting.
Nov 09, 2016 | Cars & Trucks
Door lock for Turbo AIR
How to remove the 3 locks from the panel. Both side of the panel are riveted. How to remove the panel to reach the 3 locks.
Jul 21, 2013 | Turbo Air Reach-In Refrigerator- 3...
My 2001 Alero Driver Door Shocks Me Every Time I Exit the Vehicle
This is usually a sign of an alternator getting bad. It can also have problems with bad ground wires . You can buy anti static rubber wire straps that hang from the back of your car. This grounds everything better and decreases static electricity. It also is good for car sickness. If your alternator is overcharging, you may get a shock, so I would have that checked out first, than a short in ground wires. Hope this helps
Jan 02, 2013 | 2001 Oldsmobile Alero
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
How do I change the door springs on my GST 40DF
We have a wide range of new hinges, door closers, and gaskets to help you get the correct seal & close for your commercial Turbo Air unit. We can even help locate the exact part you need just shoot us an email with your model and serial # and the part you need and we'll help make this process super simple! Coolergaskets.com
orders@coolergaskets.com
Aug 10, 2012 | Turbo Air Green World by 2 Door...
The left hand door is energized and shocks people when they open it. My understanding is that there are wires in the door, which power a heater. Is this heater necessary? Can the power to the door be...
Yes. The heater is there to prevent condensation. If you disconnect it you may get moisture on the glass. If you cut the wires be sure to tape them up.
Jan 29, 2011 | Turbo Air 72 cu. ft. / 2039 liter...
Where can I order extra shelves and support clips for GST 40GF
Call Rick at Restaurant Parts and More in Ohio. Give him the model and serial numbers and he can match what you need. FYI, most Turbo Air freezers are also Masterbilt. Turbo Air does the private lable thing for Master bilt.
Hope this helps.
Mar 11, 2010 | Turbo Air Freezer Green World by Bottom...
The air suspension keeps failing and i have no shocks, the air conditioner does not work every single year. the running boards do not work. The door ajar is always on
THE DOOR AJAR SWITCH IS THE DOOR LATCH SPARY WITH PB BLASTER & THIS WILL UNSTICK DOOR AJAR SWITCH OPEN & CLOSE DOOR 10 TO 15 TIMES THEN RUNNING BOARDS WILL START WORKING AIR RIDE O WHAT FUN HAVE SEEN AIR PUMP GO BAD ALSO AIR LINES LEAK AT PUMP THERE IS ALSO A LEVEL SENSOR IN REAR OVER AXEL THEN THERE IS THE AIR SHOCKS [AIRBAGS]
Sep 29, 2009 | 2003 Lincoln Navigator
Self closing doors don't self close any more
This problem can be corrected by adjusting the hinges.
May 09, 2009 | Turbo Air MSR-49NM Refrigerator Commercial
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
