Question about Gateway 7330GZ Notebook
No back up copy for redtslling on my lp
Any way i can burn a install disk,that will let me run in safe mode thanks donns
  • Puneet Jain
    Puneet Jain May 11, 2010
    Are you not able to boot in Normal Mode. Could you please clarify the problem if remains any.
    Regards
    ELLIN
    Guru:
  • 558 Answers
If you have not reinstall OS on Laptop, please go for it and let me know if you need any further assistance.
Regards
ELLIN
Posted on Sep 17, 2008
Have a virus need to get it out need a free nopay tape of antivirus can u help none is working???
If you can download this scanner from mbam called Malwarebytes: http://www.malwarebytes.org/ Once you run this on the target computer you can do a full scan and get rid of the virus, it catches most nasties.
If the virus stop any antivirus from running, you may have to boot into safe mode and run it from a USB device or burn it and run it from a disk. To boot into safe mode :
Turn the computer on or Restart the computer
Start tapping the F8 key. The Windows Advanced Boot Options Menu appears.
Ensure that the Safe mode option is selected. And boot into safe mode.
Hope this helps,
Cab
Mar 05, 2011 | Computers & Internet
I loaded Windows Internet Explorer 8, and it installed it as an update in May 2356 (the year!). I am now having all sorts of windows is not working messages and would like to know how to fix this. Thank...
Hi I suggest you go to system restore but beware that some program installed prior to chosen date will not appear. To proceed, go to start menu, choose accessories, choose system tools, then choose system restore.
Another way is to run your computer on safe mode to fix some error in your computer because of faulty driver or multiple driver installed with the same driver or faulty installation of software that make your computer to run slower and appears some errors. Here how it works, just restart your computer and when booting press F8 and choose safe mode to fix the errors run your computer on safe mode. Then defragment your computer to fix some errors also by going to start menu, choose accessories, choose system tools, choose disk defragment. After finished, restart your computer and check if it runs faster that before.
If you have, systems back or recovery disk, install it by insert the CD/DVD to CDROM and rebooting your computer. Run the CD as installer and it will install the systems back up. It will go back your computer to normal before.
I hope it helps you.
Jan 13, 2011 | Microsoft Windows Vista Home Premium DVD...
I need to back up files, because spywear has taken over my Asus laptop preventing me from using any programs including the internet. It does not have a disk drive, nor do i have an external or flashdrive....
Try to download Malwarebytes on another pc and burn it on cd and install on this computer. Since you said no disk drive not sure does this include CD drive and if so you can pick up removable Tumbdrive from any store(like walmart,bestbuy) for about $10 and use this to put the saved file on. It is same as cd installation. Run this software and this will clean up most viruses and spyware issues. You can get up to i believe 24GB-32GB removable tumbdrive which should be enough to back up everything you have. Just open your MyComputer and copy and paste all the info in to removable drive that you wish to backup. If you have issues with computer use because of spyware you can boot in to safe mode and do it from there. Restart your pc and when screen turns black keep on pressing F8 key until you get screen that says advanced start up menu and choose safe mode and choose ether your name from users if there is an option or choose Administrator. Some times it will ask for password but you can most times just leave it blank. Once in safe mode it is same process for backup.
Nov 03, 2010 | Computers & Internet
Dell inspirion 530 Black sreen at boot up with blinking cursor
HI there.
Hit F12 - enter diagnostics - then run them
It should from memory run a test called 'DST' which stands for disk short test. If this passes OK your disk is 99% ok. If OK then (my guess is you have WinXP) boot the XP install disk and attemp to install Windows. If the installer detects a version of windows already on the disk it will ask you "if you wish to repair the copy already installed"
If it does hit yes - ( you wont lose your data however I hope you have backed up)
After it has finished your done.
Hope this helps you out.....Mark
Aug 28, 2009 | Dell InspironTM 1501 Notebook
My IBM thinkpad wont start
first of all we need to know what operating system ur using......
iam presuming ur using XP....
have you tried copying user32.dll back to the c:\Windows\System32 directory from the XP disk, another computer, or parallel install of XP?
If you can get to Safe Mode or Even Safe Mode Command Prompt you may aslo be able to run "sfc /scannow" at the prompt and get Windows to check all of it's system drivers and replace any that are found corrupted.
if ur not able to access through safe mode
if you are making it to the boot menu options you may try "Last Known Good Configuration" or something like that... if you are unable to get that to work either then you best bet is probably to try and run the Recovery Console from the XP CD. If that doesn't work you could try messing around with either booting XP Pre from a boot CD and copying files to wherever you need, or installing a parallel copy of XP, booting to that and copying files to your old copy. You can also try installing over the top of the existing XP but that would be my last effort as it could permanently destroy data you might be trying to keep.
if it still doesnt work
I think you may be looking at a re-install if your system is that messed up.
hope i was able to help
if u felt so... dont forget to rate my service
thank you
have a nice day
May 01, 2009 | IBM ThinkPad T40 2373 Notebook
Basically last night i went to swtich it on and i got a blue error screen and it said the system needed to shut down and then it switched off. Then when i turned it on again i got the option of starting it...
You can repair windows without deleting your files. Your files will still be intact. To do this, ff. these steps:
  • Insert your WinXP disc.
  • A message will appear saying "Press any key to boot from cd", you can press Enter key.
  • Windows will start. Wait 'til the Terms of Agreement shows Press F8 to agree.
  • There will be options to install WinXP or to use Recovery Console. In this time choose Install WinXP.
  • It will now search for your previous WinXP installation.
  • This section now let you choose whether to Install a fresh copy of WinXP OR to REPAIR your windows.
  • Choose REPAIR so that your files stored in your harddisk will not be deleted.
  • Wait 'til it finishes the installation.
*Drop a comment when done. Feel free to ask me. I will gladly assist you.
Dec 28, 2008 | Acer Aspire 5920-6727 Notebook
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
I have a pc which is infacted. I cannot use anything. not even go to start. It is a windows xp oprating systme. I can get to it in safe mode. It is a compaq nx9030. restore dosenot seem to work on it
if you can get into safe mode, i would recommend you to save all your files (just Word Documents, Excel and so on) and completely format your computer from scratch.
Like .. insert the Windows CD.. and select Install Windows... Option, (you know, all the wizard process like copying , installing, settings... all that stuff)
thats the easiest way to get your computer working trouble free.
Nov 06, 2008 | Computers & Internet
Cannot get out of running windows normally
You didn't loose you work, windows only got corrupted as what often happens. Start up into safe mode, then run "scan disk" and select fix errors automatically, it might take a while to run. Maybe with a little luck it might find some errors and fix it.
Worst case situation - put the hard drive in another computer that boots in order to back up work, then put it back in your machine and buy a copy of windows xp. Then install drivers from Acer's website. (might have to use a jump drive with another machine to install first network drivers on your machine)
Hope this helps maybe a bit......
Apr 25, 2008 | Acer Aspire E360 PC Desktop
Gateway 7330GZ Notebook Logo
19 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
