My computer monitor will sometimes come on at start but then the backlight turns off after 6 minutes. Sometimes it does not turn on at all. If I hit the ctrl and F6 keys at the same time multiple times in quick cession the backlight will come on for a short period of time. This seems to rule out the inverter.
This doesn't necessarily rule out the inverter. I've had inverters with intermittent problems that had the same effect, so having the inverter tested is the only way to rule it out. Other possibilities are a bad connection, a corroded/dirty pin or socket in a connector, a bad ribbon/cable, and a failing backlight. If it is a failing backlight, the entire screen will need replaced, as the screen is considered a sealed unit and the backlight isn't available and not considered a replaceable item. Also, it's rare, but it could have a faulty motherboard component or video card. I'm leaning towards a faulty backlight, but keep in mind the inverter and cable possibility. Start by checking and cleaning all connections.
hi i have a travelmate 230 and i was trying to download a driver device for the display on my laptop...
(More)
hi i have a travelmate 230 and i was trying to download a driver device for the display on my laptop it is all funny when you try and play games or even type
i have acer travalmate 2420 model when i am trying to plugging the adapter then the adapter led is...
(More)
i have acer travalmate 2420 model when i am trying to plugging the adapter then the adapter led is switching off and laptop is not going to start. it does not having the battery backup please suggest me what can be the problems
my acer laptop keeps comming up with a fat32 and says disc inconsistency and keeps shutting down...
(More)
my acer laptop keeps comming up with a fat32 and says disc inconsistency and keeps shutting down after a while is a travelmate 4200
Acer Travelmate 230/280 series - Model No MS2132
I am having trouble with recording through the...
(More)
I am having trouble with recording through the microphone socket - is it stereo or mono.
If its mono it explains everything!
