Question about RCA HD52W56 52" Rear Projection HDTV
Have a weird problem M50WH74S RCA
Turn TV on, have sound but the only picture I get is a white screen with a black bar across the top and black dots everywhere else. And the light behind the white screen changes colors like a light show. I cant seem to find ANYTHING or anyone who has had this problem before! What could it possibly be? Oh and the LED light isnt blinking like it would if the bulb was bad.
  • markyetter18 Jan 17, 2009
I found out tht it could be the (DMD) Digital_Micromirror_Device i dont know if that is you problem or not
Posted on Mar 09, 2009
Rca dlp model /page-2
White dots on a DLP are ALWAYS a DMD chip problem, you can find these online like at Discount-Merchant, they are easy to replace you can find videos on youtube, they are sometimes called DLP chip.
Easy to do for a fairly experienced or handy person!
Feb 21, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
Have a rca 61" tv
What is the model number of your TV?
Jun 02, 2011 | Televison & Video
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Rca m50wh74s HELP
Sounds like a bad high voltage transformer (FBT). Call a service center.
Jan 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
HP flat screen tv
our hp flatscreen sometimes has a black strip across the top of the screen....resembling something "leaking"
Apr 30, 2007 | HP PE4200N 42 in. EDTV Plasma Television
Rca tv no picture
You can turn up Screen control in back of set on the High Voltage Transformer and see if you see anything like a thin white line going across screen. If this is happening then it's your vertical IC output gone. It will have to be changed and a 100uf@50v cap in the same area.
Feb 07, 2007 | RCA 24F512T 24" TV
RCA HD52W56 52" Rear Projection HDTV Logo
227 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
