Question about Video Game Consoles & Games
Cant connect to servers with alot of players though netgeat but can directly off cable modem
    Scholar:
  • 60 Answers
You need to open the appropriate ports so your console can bypass your NAT... If you goto your console manufacturer's web site they will almost always list the ports that you have to open to allow your console to function properly behind a NAT.
Once you find the ports you need to open you can call netgear's tech support and they can walk you through opening those ports. Or you could come back here and we'd most likely be able to help ya.
Posted on Sep 17, 2008
Hp a345w desktop pc dcs server not found conflict
what OS, we can NOT GUESS your operating system.
so where are you , home or star bucks.?
what is your connection, wifi, ethernet, or others?
a desktop pc can have vast ways to get internet.
1: modem dial up (i bet not this, nobody uses this now, 99.9)
2: cable modem, sat modem, fiber modem to ISP
3: USB wifi dongle, on PC and to local router.
4: PCI card wifi. , to router.
5: ethernet wired to router or modem direct. a cable wire. CAT5/6
one can even have direct wired ethernet to the cable modem
or you might have wired to wifi router (2 ways to connect there)
NO OS stated
no connections stated.
my guess is DCS, means DHCP not found, or DNS not found.
lots of causes, but I will not attempt to answer for all 6 ways.
sorry
May 30, 2017 | HP Computers & Internet
How do I connect cable modem to cisco 3560 switch and configure it?
The cable modem will need to go through a router because it needs a NAT and PAT translation table, connecting the cable modem direct would lose the ability to get to the internet.
Jun 05, 2012 | Cisco Catalyst Compact 3560-C PD PSE -...
I have connection between my mac 10.4.11 and the zyxel router and I have connection between the zyxel router and an old compaq desktop upstairs but I cant access the internet, which is last mile. Ive...
dchp problem. sounds like the modem is doing dhcp that's why it works plug in directly. disable the dhcp server in the router go to Network > DHCP Server > General in the router and disable it. only the modem or router can do dhcp.
Aug 02, 2017 | Zyxel NBG-417N Wireless Router
Cant get online when i run a test it fails on playstation net work then afterwards says you have been disconnected from media server
If you are using a router, the problem probably has to do with the router. In order to find out, disconnect your PS3 from the router and plug it directly into you modem. If your modem is not near your playstation 3 then move it close to the PS3. The modem plugs directly into your cable line so there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS3 to your modem, press the reset button on the modem. Turn your PS3 on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually) If you are getting a connection then you are ready to go.
Thank you!
May 18, 2010 | Sony Playstation 3 (PS3) Console
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Cant connect with netgear wgr614
I suppose you pluged the cable from the Modem to the WAN port on the Router. If you are using wireless, try to assign IP address, Subnet mask, Default gateway instead of DHCP(Automatic configuration).This is done by selecting the WLAN and choosing Properties - TCP/IP. If you have a Proxy Server then enter the DNS server addresses ok. Good luck
May 04, 2009 | NetGear WGR614 Router
I cant go on youtube
First off, In firefox, go to tools > clear private data, and try again. If that doesn't work, ensure you have flash player installed you can tell this if you can see the video playing. But looking at your error, it should be a flash player problem.
If that doesn't work then try unplugging and replugging your modem (dialup/adsl/cable/satellite or whatever you have) and (if applicable) your router. Reboot your computer, and try again.
Mar 07, 2009 | Computers & Internet
Connecting my router
Betty,
Did you unplug the power to the cable modem for at least 15 secs, prior to plugging in the router?
This in fact does fix alot of startup problems.
Cheers,
gurutim
Feb 28, 2009 | Cisco Computers & Internet
Router stopped working altogether
Please check your cable connections; are the lights blinking? try connecting your computer directly to the modem dsl port that is connected was to the router if connection can be restored.
Nov 11, 2007 | NetGear WNR854T Router (WNR854T100NAS)
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
