Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
JKenmore Range Kenmore Range We unplugged the range to leave for the hurricane. When we got home I plugged it in and set the clock. It then started beeping and displayed F-1. What now?
  • 943 Answers
Hi. thanks for the question. the fi failure code says to replace electronic oven control. sorry . thanks the appliance doc
Posted on Sep 30, 2008
We had a power outage and now the oven will not come on. cannot set clock etc.
Have you checked your breaker box? It could be that the breaker for the range popped to the off position. If the breaker is still on, try carefully unplugging the range, leaving it unplugged for a few minutes, then plugging it back in.
Dec 27, 2010 | Maytag 30 in. Electric Single Wall Oven...
Tone and F1 message
If you are lucky it was caused by a stuck keypad.Usually you can press all the keys at random and unstick a keypad.
If it re-occurs and will not unstick you must replace the complete clock control.
Apr 28, 2009 | Kitchen Ranges
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
The control panel stoped working.
Unplug the range for 30 seconds, then plug it back in.
If it does not work,
Replace the clock.
Mar 12, 2009 | Kenmore Kitchen Ranges
No oven no burner
The F13 indicates a problem with the EOC (Electronic Oven Control board). This can be caused by a power surge or glitch through the electrical supply lines. You can try disconnecting electrical power completely from the range by unplugging it. Leave it unplugged for a few minutes. If the fault code returns when you plug the range back in, then the EOC will need to be replaced.
Dec 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Kenmore electric Range model 635040L0
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Sep 24, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
But please reply back with your full model number so we can help you.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 15, 2008 | Kenmore 63672 Convection/Microwave Oven
Stove replacement?
All the fault codes I could find on Roper indicates that this is an Electronic Oven Control (EOC) failure. This is your clock assembly. Searspartsdirect.com carries the part for about $47. I think for that price, it may be worth the attempt to repair the range, vice replacing one at a cost of hundreds of dollars. Just type in your model number and you can locate the clock assembly under the "Backguard Section" heading as item number 17 (part number WB27M10). I hope this helps you.
Aug 17, 2008 | Roper FGP325K Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
114 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
