Question about Intertherm Heating & Cooling
Water heater burner flame is low does not heat water it was working this morning pilot stays lit
  • Anonymous Mar 16, 2014
    the burner nob temperature regulator it's at max. but the flame in the burner is very low and the water is a bit cold
  • Anonymous Mar 26, 2014
    The second and third buttons are stuck and remain on. Heater will only work now will all 3 burners lit. How do I release the buttons?
  • 3 Answers
Frist did this heater go under water if so call the pros.this can be do to dirty orfic on burner. clog presure regulater at gas meater check other gas applince.
Posted on Sep 17, 2008
Richmond gas hot water heater. After I light pilot and main burner why does it flame out in 15 seconds?
If you had to light the main burner manually, something is wrong. Once you light the pilot and it stays lit, the flame heats the thermocouple to open the gas valve and fire the main burner. Either or both of the components you replaced could be defective.
Sep 10, 2015 | Water Water Heaters
Laars pool heater's burner wont stay lit
Check the burner, the holes may be plugged, especially at the beginning of the season. Same happens to the pilot light tube. Spiders love to make nests inside those small holes clogging everything up.
Aug 13, 2014 | Teledyne Laars Pool & Spa
Gas burner wont stay lit
Is it the Pilot, or the main burner that won't stay lit?
The pilot has a little 'flame rod' in the path of the pilot flame, that conducts a tiny current thru the flame, to a detection circuit-- assuring that there is a pilot flame-- If that rod get's dirty, it can cause false trips. Is that any help?- Mack B
Oct 25, 2013 | Honeywell Pilot Burner for Natural Gas,...
Hot water tank doesn't stay on
Suspect the thermocouple that senses that the pilot is lit. This device prevents the gas burner from coming on when if the pilot goes out, but if it's defective could cause the burner to shut down even when there is a pilot flame. Also check the position of the thermocouple in relation to the pilot flame. The tip of the thermocouple should be right in the middle pilot flame.
Oct 11, 2013 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
GCV 40 100 Burner and pilot shuts off when heating up
Get more fresh air to the unit.
Clean the air intake/ flame trap/ flame arrestor located on bottom of tank.
Post question on pro water heater forum.
Add a comment with type of gas control valve, for possible troubleshoot.
Copy following link to read service manual by type of gas control valve:
Aug 17, 2012 | A.O. Smith GCV-40 Promax Residential Water...
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
Sep 21, 2011 | Water Heaters
Pilot lite does not lit please advise what to do.the burner stays on if lit directly with open this dangerous.
What you describe is typically caused by a faulty thermocouple. The thermocouple senses the heat from the pilot light and TURNS OFF the pilot when it no longer senses the heat.
When the thermocouple turns off the pilot, it's not necessarily dangerous, but the water heater won't turn on without help.
Mar 23, 2011 | Water Heaters
We change the burner for the water heater, it stay li ari=ound 35 minutes, heat the water and after is turning on completely, even the small flame don't stay lit. What we need to do?
you mean it is only staying on for 35 minutes, if this is the case, then readjust or replace thermal coupling, if bad it will not sense the flame or pilot light. it has to be in pilot light flame as to work properly. ( this is for a gas hot water heater). if bad it will shut gas off to heater.
Aug 05, 2010 | Water Heaters
Pilot won't stay lit
What color is the pilot flame? Yellow/orange or blue? Look at the tip of the thermocouple where the pilot flame is heating. It should be a smooth round tip. If the tip is partially burn't off or ridgid, replace the thermocouple. After the pilot is initially lit, does the burner come on too? Take a flashlight and look up inside the water heater above the burner. Do you see a lot of soot build-up? Light a match at the top of the water heater at the draft diverter (it attaches the venting to the water heater) and blow it out and see if the smoke gets sucked into the diverter or blown out. It should get sucked in. If not you may have vent blockage or soot build-up.
May 15, 2010 | General Electric GE SmartWater Household...
Heating & Cooling Logo
180 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
