Question about Dell Dimension 2400 PC Desktop
Dell desktop -- ethernet connection
I had my ethernet connection go down on my Dell desktop; I get a limited or no connection message; it cannot seem to locate my IP address. This is built-in ethernet hardware. Is there a way to re-activate this ethernet device and restore my internet connection.
Apparently, this Dell does not take a 10/100 Ethernet card which plugs into an empty slot (I have 3 empty slots on the motherboard).
Any ideas, please?!
  • vincent munch Sep 20, 2008
    I went back into the network connections and saw that I had missed an obvious fix; thank you JoshBlaine.
    Scholar:
  • 65 Answers
Whenever I get a limited or no connection message I right click on the network icon in the taskbar that's giving the message and select repair. Sometimes that doesn't work and I select disable then enable again. You can also do this from network connections that may be found in Control Panel.
Make sure you have DHCP selected. To do this right click on your ethernet connection in network connections, select properties. Scroll down in the list to the tcp/ip, select it then select properties, then make sure it is set to automatically detect on the IP address and the DNS address.
This problem can also happen if you are not connected to a DHCP server in which you would do the opposite of above and type in your IP address, subnet, gateway and dns addresses, though it is most likely not the case.
You can go to device manager and uninstall the network device. Then reboot and it will find it and reinstall it. Then see if that works.
You can get to device manager by right clicking on My Computer or computer in vista, click on the hardware TAB then select device manager then look on the list for your network card.
Also make sure you have the latest driver for the network device.
Sometimes things can cease to function after an operating system update.
Have you installed anything recently. One thing that can solve problems is system restore.
Try restore the system to a date before the problem occured. In windows xp go to the start menu, all programs, accessories, system tools, system restore.
If none of this works you can purchase an ethernet card or replace the motherboard. The ethernet card of course would be the least expensive route.
Posted on Sep 17, 2008
  • fizzneedhelp Jan 13, 2011
    its too advance can u explain it like im a ten year old because im 18 n english is not really our mother tongue so it will really be a big help if you do email me at fizz_ul16@hotmail.com
Why my a720-5730 desk top the ethernet connection turn on and off ?
which internet connection are you using?
call your isp for so.
try putting ip address manually.
if all above doesnt work change your ethernet card
May 17, 2014 | Lenovo Computers & Internet
Reinstalled Windows XP on a Dell Dimension 8400 and The local area connection is not detected. Cannot seem to find drivers through Dell support
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Sep 11, 2013 | Dell Dimension 8400 PC Desktop
Internet not conect
If you are unable to connect to internet. There are few things you can try:
1) Reinstall the Ethernet drivers. Go to control panel> add/remove programs> uninstall the Intel or Realtek Ethernet drivers.Then reinstall the drivers from the motherboard disc provided with this pc. Make sure you install only the ethernet drivers.
2) If your pc is giving any kind of error message like limited connectivity then its a problem with your ISP(Internet service provider) or the windows operating system itself. Call your ISP and let them check the issue if they can't help go for a repair install of windows using the disc.
Hope that helps!
Sep 17, 2011 | Dell Dimension 4500 PC Desktop
How do I connect my dell 4500 to an ethernet connection? My desktop does not seem to have a connection port. My DSL company (AT&T) sent me a new modem motorola MSTATEA and it does not have a telepohne...
The Dell 4500 uses an add-on PCI card for ethernet.
You may not have ordered this PC with one.
You can purchase a card for this system, if you are comfortable with installing additional cards into the system. The system is
Here is the link from Dell on installing cards. http://support.dell.com/support/edocs/systems/dim4500/replace.htm#1138309
Amazon sells these cards: http://www.amazon.com/s?ie=UTF8&x=0&ref_=nb_sb_noss&y=0&field-keywords=PCI%20network%20card&url=search-alias%3Daps
Jun 15, 2010 | Dell Dimension 4500 PC Desktop
I am trying to connect my Dell XPS one PC to a D link router, but I keep gettingan error message that the ethernet cable is not properly connected.There is only one port and the cable is correctly...
You need to be more specific as far as your layout. On your modem there is only one Ethernet port that needs to have a cable running into your D-Link router's WAN port. Now take a second Ethernet cable and run it from an available port on the D-Link router to your Dell XPS.
You may need to check that you have the correct Network Adapter driver installed. They are a bunch of scenarios that could be your problem. But with the little bit of information you provided, its hard to narrow it down for you.
Feb 18, 2010 | Dell XPS One Desktop PC RED-20" HD...
For having my new "ADSL" box installed, i need to connect it on my DELL 5150 dimension via an ethernet cable. It doesn't work. It seems that i have no ethernet drivers on my Dell PC. Is it possible ?
Hi,U need check in the BIOS Ethernet is enable ...? than check in Device manager if it is Yellow mark in Ethernet icon if it there u need uninstall the drivers and reinstall.
Feb 08, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell XP 200 Dimension ethernet port
Hello.
I'd suggest testing with another computer and the same Ethernet cable to your modem to see if the results are the same and to narrow down which component is the problem.
Was it always slow with this setup or did something change.
Is the Linksys adapter connected via USB ? That would be slower than an internal adapter.
Try updating the Linksys adapter software - Device Manager - rightclick - update driver.
Hope these suggestions help.
Dec 23, 2009 | Dell XPS 200 PC Desktop
Ethernet driver is not installing
are you installing the correct driver? whats the error message you are getting?
Jul 20, 2009 | Dell Dimension 1100 PC Desktop
Ethernet port connection failure
You could get another ethernet card from ebay for less than $10. Although, honestly, I don't think the port could have oxidized in 5 years. What is the error message(s)?
Mar 29, 2009 | Linksys Wireless-G WRTP54G Router
Ethernet Driver
Yes, you need to download Enthernet driver for you system and you can easily find on Dell's website.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_CEL_2350&os=WW1&osl=en&catid=&impid=
you can even search driver using serivice tag which you can find on your computer.
thank you
and do not forget to vote all answers.
Jan 11, 2009 | Dell Dimension 2350 PC Desktop
Dell Dimension 2400 PC Desktop Logo
244 people viewed this question
Alun Cox
