Question about Ovens
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
  • Anonymous Mar 24, 2014
    After switching off at wall & cleaning, cannot get it started again
  • 4,323 Answers
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 19, 2011
JKP70-27" SINGLE CONVECTION WALLOVEN
Replace the transformer and hope nothing else went bad. Good luck!
May 27, 2014 | GE JKP70 27" Single Electric Wall Oven...
Some keys on keypad will not work
Those pesky keypads. It is common for the keypads to stop making contact when pressed or will stay making contact and cause failure code errors. You can try removing the ribbon cable from the control board (shut off power first) Carefully remove the ribbon cable from the mounting bracket. usually there are small tabs that must be pulled up on each side of the bracket before you can remove the ribbon. Take a pensil eraser and carefully clean the contacts on the ribbon and reinsert it back in the bracket. If this fixes it then fantastic. If not the touch control panel will need replacing. They are fairly expensive.
Feb 20, 2014 | GE Profile Black 30" Pt956 Self Cleaning...
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 | GE Ovens
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
GE Profile 2002 Wall oven JCKP18BA2BB Code faults
Try my solution for the F7 problem at the following link:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have shared this with over 1500 folks and most report success.
Please let me know. Also, what is your model number, how old is your oven and where are you located? I am making a study of this problem. You can email me at: hutchipop@yahoo.com
Jan 08, 2008 | Ovens
Ovens Logo
335 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
