Question about Garden
Stihl FS85 Weedeater
Have to coax to get started, then it is jittery at that.  It shots out white smoke from exhaust.  Can not get it to start now. New spark plug, clean gas, suspect it is the coil, not sure. Where can I find a part list and order parts to fix myself.
Stihl pro fs85 weedeater starts up shuts right off Will not stay running
Posted on Jul 26, 2010
  • 50 Answers
I suspect carb. trouble. Is the compression OK? Look at the spark plug after trying to start it. If it is wet, you are getting too much fuel. The white smoke indicates that. You may need to overhaul the carb.
Go on the Stihl site and customer service for information.
Posted on Feb 14, 2009
Check to see if your exhaust port is clogged up, also check you spark arrester screen located on the muffler
Posted on Aug 20, 2010
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
My stihl weed eater fs85 hard to start when hot
Try loosening the gas cap to relieve any pressure, then tightening it back up. Usually you will just need to barely unscrew it and then screw it back even before you pull the rope.
Jul 13, 2014 | Stihl FS 85 Weed Eater
Stihl FS85 starts fine, But not take full throttle
Pumping the primer bubble while the engine is running should cause the engine to over fuel and stall (if the tuning is correct). Sounds like its not fueling enough, pumping the primer is forcing fuel through the carb causing the engine to pick up rev's, but this is soon exhausted which is why it wont rev on the throttle.
* Check that the fuel line is not damaged and drawing in air. (if this is intact try the next step)
* Strip and clean the carb. Replace any diaphrams if needed.
* Check gaskets seal between carb, air filter and cylinder.
Just out of curiosity what standard carb settings did you use.?
May 23, 2013 | Stihl FS 85 Weed Eater
HOW DO REPLACE TRIGGER ON STIHL WEEDEATER
Im figuring the FS85 has the cow horn bars,of which there are 3 types of controls. Here's the Illustrated parts list diagram. If you would like the full IPL please contact me further and i will send it to you.
091def0c-1a1d-477c-8225-a6693552ec07.jpga3d9b8d2-2c74-41bd-b2ce-7b7b04029ad1.jpg2b7c3b7f-fa69-4d03-9e02-cad641715bf7.jpg
Apr 17, 2013 | Stihl FS 85 Weed Eater
MY STIHL MS 290 CHAINSAW WONT START
Check your carburetor. You probably have a bad one and will need to replace it.
Oct 25, 2012 | Stihl Garden
Stihl fs85 gives off white smoke while running
change to stihl ultra oil and make sure you ratios are correct. also replace spark plug and spark arrester.
Oct 07, 2012 | Stihl FS 85 Weed Eater
Wont start when hot
might be coil ? you can test it with and ohm meter should be within specs on both primary and secondary sides ? but try this first to see if its a vapor lock or fuel hose issue ? when it wont start get you a can of starting fluid and spray the air filter see if it restarts then ? this will tell you its fuel not spark ? then you can recheck hoses and primerbulb ? hope this helps
Aug 27, 2009 | Craftsman 25cc Gas Line Trimmer
No power fs66 stihl weedeater
Hi When you cleaned the muffler out did you also clean the carbon out of the port on the cylinder as this can be blocked as well. Also you will have to retune the carby, There should be 2 screws 1 for low speed marked l on the carby body and 1 marked h for high speed to start with they should be set at 1 & 1/2 turns out from closed the low speed you set at an idle and the high speed you set at full throttle. Hope this helps.
Aug 03, 2009 | Garden
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
Stihl FS85 Stalls when warm and gas is given will still idle
Make sure the carb settings are correct. Screw both tuning screws all the way in and then turn ot anticlockwise the following settings H 3/4 of a turn, L 1 full turn. (this is set to the standard setting)
Jul 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
3,889 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
