Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Red light comes on for no reason. Dan...
By larosao on Sep 17, 2008
My danby dehumidifier is about 5 months old. For the first couple of months, everything was working fine. Then, at random times, the red light would come on for no reason that i knew to troubleshoot. I use the bucket for water collection. When it fills up, the red light comes on as expected, i empty the bucket, then i place back. I turn the humidifier on and just a few hours into its operation (random), the red light comes on. The bucket has not shifted, nor has it collected enough water. There is some water in it from having been running a couple or more hours, but the bucket is nowhere near full. It doesn't do this every time, but it is consistent in doing it randomly. Any reason anyone know of that this might do this? Could it be a faulty sensor? When i place it in cleaning mode, it seems to help, but no true way of knowing. I've put on self-clean mode and STILL the light would turn on.
Ideas for troubleshooting this issue?
Thanks in advance!
Comments:
Oct 08, 2008
- Hi,
thanks for the great response! That seems to make all the sense in the world. I wasn't very familiar with how the float functioned. I assumed that maybe the float was sticking due to a minor amount of humidity building from the bucket (since i fill the bucket, instead of connecting to a pump), especially after having the water dumped. So, not being familiar either with what the ''cleaning'' function does, i proceeded to clean every time i re-installed the bucket. I figured cleaning removes any remaining moisture in the dehumidifier, at least initially. This seems to have ''fixed'' my problem. I did this procedure for maybe 10 times or so before i quit doing. Since i quit, i've run it normally, and have had no further problems with the light coming on when it really shouldn't. Like i said, it generally came on more as soon after i'd re-install the bucket after dumping the water.
Bottom line, can't say how and if my solution helped. If i get back to random red light issue, i'll definitely try bigbohab's idea with the duct tape.
Same Problem
Sep 25, 2008
-   I have a DDR3008EE model and it worked fine after I purchased it in May 2008. The red fill light recently began to come on randomly and now it will not work at all. The light comes on within seconds after starting it up.-   gallogs
Best Solution
posted on Oct 07, 2008
Helpful)
bigbohab
Rank: Apprentice
Rating: 86%, 4 votes
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
My Soleus dehumidifier has stopped working after one year. The fan is running, the compressor seems... (More)
Answer
refresh-air broken control knob
Answer
None of the buttons work:power, humidity control. Basement seems to be damp still. Do we need to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dehumidifiers:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
